> Bleeding Brakes, Trouble with one caliper
Deusexmachina77
post Mar 25 2023, 10:13 AM
I replaced the two front calipers with rebuilt calipers. The system was drained. I bleed the brakes starting in the rear and going to the front. I've run into an issue with the driver's side front caliper.
I have fluid making it to the caliper, as the bottom has fluid coming out with no air bubbles. But when I went to the top bleeder, I only got air. It never filled up with fluid. I removed the bleeder screw to make sure it wasn't clogged. We peddled the car continuously, and only just air. This went on for a while.(IMG:style_emoticons/default/headbang.gif)
There are no fluid leaks in the system.
Any thoughts would be welcome.
mlindner
post Mar 26 2023, 05:22 AM
I use davep procedure, works great. Mark
Deusexmachina77   Bleeding Brakes   Mar 25 2023, 10:13 AM
davep   If you are pushing out air, then you just have to ...   Mar 25 2023, 10:19 AM
Deusexmachina77   If you are pushing out air, then you just have to...   Mar 25 2023, 10:23 AM
Deusexmachina77   I tried for 20 min. Nothing is coming out of the t...   Mar 25 2023, 11:50 AM
r_towle   I tried for 20 min. Nothing is coming out of the ...   Mar 25 2023, 12:35 PM
Deusexmachina77   I tried for 20 min. Nothing is coming out of the...   Mar 29 2023, 01:28 PM
Superhawk996   I kept waiting for air bubbles to stop. Air bu...   Mar 29 2023, 07:04 PM
emerygt350   I use a ten year old. I open, he pushes n holds, ...   Mar 25 2023, 03:42 PM
914e   I use a ten year old. I open, he pushes n holds,...   Mar 26 2023, 11:05 AM
930cabman   I use a ten year old. I open, he pushes n holds...   Mar 27 2023, 01:57 PM
davep   Yes, the correct procedure is to press pedal 2 or ...   Mar 25 2023, 04:33 PM
IronHillRestorations   Bleeding Brakes   Mar 25 2023, 05:45 PM
bkrantz   Pressure bleed. Vacuum bleed. Gravity bleed.   Mar 25 2023, 08:33 PM
mlindner   I use davep procedure, works great. Mark   Mar 26 2023, 05:22 AM
technicalninja   Sometimes the bleeder feed inside the caliper is c...   Mar 26 2023, 09:04 AM
Deusexmachina77   Don't get brake fluid on you. It's hydrosc...   Mar 29 2023, 01:33 PM
emerygt350   We double checked the venting this morning and did...   Mar 26 2023, 02:44 PM
davep   THE official statement on venting clearance (post ...   Mar 26 2023, 04:36 PM
Deusexmachina77   Thank you, everyone, for your advice, as I will us...   Mar 28 2023, 09:03 AM
davep   One aspect of the "pump the pedal" metho...   Mar 30 2023, 02:45 PM
Deusexmachina77   Finally got everything back together. I ended up u...   Apr 1 2023, 07:16 AM
- Lo-Fi Version Time is now: 27th December 2024 - 09:18 AM
