> OMG WTF, if it's not one thing it's another
Type 47
post Mar 26 2023, 07:12 PM
so we've been battling a tuning issue which is being discussed in another thread, so I don't want to muddy the waters with another issue, hence the new post.
So, i'm sneaking up on this carb tuning issue and get the car idling to do the carb tune stuff and I notice this shxt...
I get the car started, rev it to 2-3K for a little bit until it establishes idle at about 1,200.
so I get out to start fooling with the carbs and notice it's not smoking with white smoke like it was the last time. Outside temp was about 50, now outside temp is 64ish.
It's freak'n spitting out oil. There is a spray pattern out the tailpipe about 12' long.
When we filled the oil I instructed 4 qts but not sure if son put in the whole 5 qt Mobil One container in. Also, on initial run he thought it was a little low, on oil, so we put in another 1/2 qt.
Engine has been sticking a (measuring) really high ever since.
Has a piston ring gone south??
Is the oil overfill causing this issue?
Why did this just start happening?
bossboy302
post Mar 27 2023, 12:56 PM
Man, I feel your frustration. I've peeked at most of your recent threads. Your struggles seem to tumble down to the basics. SO, these suggestions are not meant to insult, but a bit of a reality check:
Maybe keep your son(s) in their own garages(s).
Get an experienced 914 tech to help.
Read and study a bit more before diving in.
or....Go to Fiji... (IMG:style_emoticons/default/sunglasses.gif)
Type 47
post Mar 27 2023, 07:23 PM
QUOTE(bossboy302 @ Mar 27 2023, 10:56 AM) *
Fiji? Hmmm.
I did work on it some yesterday by myself.
Drained all the oil today and letting it drain overnight and then put some dino oil back in before doing anything else.
Type 47   OMG WTF   Mar 26 2023, 07:12 PM
nditiz1   When you say "He thought it was a little low...   Mar 26 2023, 07:29 PM
Van B   :agree: I doubt it’s low on oil… But you can a...   Mar 26 2023, 07:36 PM
mihai914   Why don't you start all over with the car just...   Mar 27 2023, 07:32 AM
VaccaRabite   Put the car level somewhere. Check the oil. If i...   Mar 27 2023, 07:38 AM
Type 47   Put the car level somewhere. Check the oil. If ...   Mar 27 2023, 11:06 AM
Type 47   so we've been battling a tuning issue which i...   Mar 27 2023, 11:04 AM
Van B   see if it smells like gas when you drain it.   Mar 27 2023, 11:17 AM
bossboy302   Man, I feel your frustration. I've peeked at m...   Mar 27 2023, 12:56 PM
Type 47   Man, I feel your frustration. I've peeked at ...   Mar 27 2023, 07:23 PM
Type 47   We are back up and running. Not great but close t...   Apr 6 2023, 05:32 PM
Superhawk996   Good job - making progress. So the 32mm venturis ...   Apr 6 2023, 05:54 PM
Type 47   Good job - making progress. So the 32mm venturis...   Apr 6 2023, 06:47 PM
Superhawk996   How are you doing with the iteration between adjus...   Apr 6 2023, 05:58 PM
nditiz1   You should be running 28 vents. Pick up a set, as...   Apr 6 2023, 07:01 PM
Type 47   You should be running 28 vents. Pick up a set, a...   Apr 6 2023, 09:53 PM
technicalninja   I am Jedi-master class when it comes to ITB carb s...   Apr 6 2023, 07:53 PM
Type 47   I am Jedi-master class when it comes to ITB carb ...   Apr 6 2023, 10:02 PM
technicalninja   Yep, if I was in your shoes, I'd work with tho...   Apr 7 2023, 08:46 AM
VaccaRabite   It only takes about 10 minutes to swap the vents o...   Apr 7 2023, 09:49 AM
Type 47   Guys, my bad. it has 28's   Apr 7 2023, 02:36 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:11 PM
