> Help with trans case repair needed., My teener is in the shop for repair ....
Jamie
post Mar 30 2023, 09:50 AM
..of a trans housing leak as a result of a prior welding repair made years ago. The repair of a punched hole was apparently made with aluminum weld material, and has developed a leak at the welded patch. My mechanic's welder is having trouble finding magnesium welding rods to properly make the repair now, can any of you suggest a source for these mag rods? This info is way above my pay grade when it comes to welding! (IMG:style_emoticons/default/hissyfit.gif)
Geezer914
post Apr 2 2023, 01:36 PM
Geezer914
I had a Triumph TR4 back in the 80's. The aluminum thermostat housing developed a crack and was leaking. ground out the crack and filled it with JB Weld epoxy. Never leaked and that is under 12lbs. of pressure and heat!
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th January 2025 - 07:43 PM
