jims914 |
Member ![]() ![]() Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region ![]() ![]() |
Anyone have any Pros or Cons for a 123 ignition D-jet tune-4-r-v-p unit for 74 2.0 ?
Lockwodo |
Member ![]() ![]() Group: Members Posts: 202 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
Yes, my 914 was "bucking" under acceleration. I replaced the throttle position sensor and cleaned the trigger points several times but the problem remained. Installing the 123 ignition took care of it.
gonzo54 |
Orange Crush ![]() ![]() Group: Members Posts: 227 Joined: 10-May 19 From: Seal Beach, CA Member No.: 23,112 Region Association: Southern California ![]() ![]() |
Yes, my 914 was "bucking" under acceleration. I replaced the throttle position sensor and cleaned the trigger points several times but the problem remained. Installing the 123 ignition took care of it. That's interesting-I've been fooling with the TPS including a new 914 Rubber board had the trigger points out several times to clean and the bucking problem always comes back. So how much is the 123 ignition and what is the best model for a 2056 with a mild Webcam? Thanks-Rick |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Yes, my 914 was "bucking" under acceleration. I replaced the throttle position sensor and cleaned the trigger points several times but the problem remained. Installing the 123 ignition took care of it. That's interesting-I've been fooling with the TPS including a new 914 Rubber board had the trigger points out several times to clean and the bucking problem always comes back. So how much is the 123 ignition and what is the best model for a 2056 with a mild Webcam? Thanks-Rick Low speed bucking was a problem I couldn’t get rid of, 123 solved that issue, I think it is associated with vacuum can problems. You need a Bluetooth version for tuning. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:07 AM |
