> OMG WTF, if it's not one thing it's another
Type 47
post Mar 26 2023, 07:12 PM
so we've been battling a tuning issue which is being discussed in another thread, so I don't want to muddy the waters with another issue, hence the new post.
So, i'm sneaking up on this carb tuning issue and get the car idling to do the carb tune stuff and I notice this shxt...
I get the car started, rev it to 2-3K for a little bit until it establishes idle at about 1,200.
so I get out to start fooling with the carbs and notice it's not smoking with white smoke like it was the last time. Outside temp was about 50, now outside temp is 64ish.
It's freak'n spitting out oil. There is a spray pattern out the tailpipe about 12' long.
When we filled the oil I instructed 4 qts but not sure if son put in the whole 5 qt Mobil One container in. Also, on initial run he thought it was a little low, on oil, so we put in another 1/2 qt.
Engine has been sticking a (measuring) really high ever since.
Has a piston ring gone south??
Is the oil overfill causing this issue?
Why did this just start happening?
Type 47
post Apr 6 2023, 05:32 PM
We are back up and running. Not great but close to where we were.
I've learned that understanding carbs/Webers is much like becoming a Star Wars Jedi.
Yoda (all you guys) has led me to knowledge but like Luke I'm just wanting to get my Starfighter out of the swamp.
I did learn to check that the carbs do have the factory 32mm venturi's, 115 main jets, 2.00 correction jets, and the F11 emulsion tube. So they are stock, not modified.
We adjusted the floats to be 10mm's, which were a little off.
It seems like when you make an adjustment with the idle adjustment screws and even the air bypass screws it takes 20 seconds or so to see a difference. so I've learned to be patient.
but like Luke, I'm still shooting from the hip.
now I've got to not touch these and figure out what's keeping it from running more smoothly.
Timing?? The 27 degree mark is there at 3,500 rpm but is bouncing. and where should timing be at idle? We can see the mark off in the distance at idle.
I wish I had known how critical it is to make sure the marks are clear and marked before we put the engine back in.
Type 47   OMG WTF   Mar 26 2023, 07:12 PM
nditiz1   When you say "He thought it was a little low...   Mar 26 2023, 07:29 PM
Van B   :agree: I doubt it’s low on oil… But you can a...   Mar 26 2023, 07:36 PM
mihai914   Why don't you start all over with the car just...   Mar 27 2023, 07:32 AM
VaccaRabite   Put the car level somewhere. Check the oil. If i...   Mar 27 2023, 07:38 AM
Type 47   Put the car level somewhere. Check the oil. If ...   Mar 27 2023, 11:06 AM
Type 47   so we've been battling a tuning issue which i...   Mar 27 2023, 11:04 AM
Van B   see if it smells like gas when you drain it.   Mar 27 2023, 11:17 AM
bossboy302   Man, I feel your frustration. I've peeked at m...   Mar 27 2023, 12:56 PM
Type 47   Man, I feel your frustration. I've peeked at ...   Mar 27 2023, 07:23 PM
Type 47   We are back up and running. Not great but close t...   Apr 6 2023, 05:32 PM
Superhawk996   Good job - making progress. So the 32mm venturis ...   Apr 6 2023, 05:54 PM
Type 47   Good job - making progress. So the 32mm venturis...   Apr 6 2023, 06:47 PM
Superhawk996   How are you doing with the iteration between adjus...   Apr 6 2023, 05:58 PM
nditiz1   You should be running 28 vents. Pick up a set, as...   Apr 6 2023, 07:01 PM
Type 47   You should be running 28 vents. Pick up a set, a...   Apr 6 2023, 09:53 PM
technicalninja   I am Jedi-master class when it comes to ITB carb s...   Apr 6 2023, 07:53 PM
Type 47   I am Jedi-master class when it comes to ITB carb ...   Apr 6 2023, 10:02 PM
technicalninja   Yep, if I was in your shoes, I'd work with tho...   Apr 7 2023, 08:46 AM
VaccaRabite   It only takes about 10 minutes to swap the vents o...   Apr 7 2023, 09:49 AM
Type 47   Guys, my bad. it has 28's   Apr 7 2023, 02:36 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:11 PM
