OMG WTF, if it's not one thing it's another |
Type 47 |
Mar 26 2023, 07:12 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
so we've been battling a tuning issue which is being discussed in another thread, so I don't want to muddy the waters with another issue, hence the new post.
So, i'm sneaking up on this carb tuning issue and get the car idling to do the carb tune stuff and I notice this shxt... I get the car started, rev it to 2-3K for a little bit until it establishes idle at about 1,200. so I get out to start fooling with the carbs and notice it's not smoking with white smoke like it was the last time. Outside temp was about 50, now outside temp is 64ish. It's freak'n spitting out oil. There is a spray pattern out the tailpipe about 12' long. When we filled the oil I instructed 4 qts but not sure if son put in the whole 5 qt Mobil One container in. Also, on initial run he thought it was a little low, on oil, so we put in another 1/2 qt. Engine has been sticking a (measuring) really high ever since. Has a piston ring gone south?? Is the oil overfill causing this issue? Why did this just start happening? |
nditiz1 |
Apr 6 2023, 07:01 PM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
You should be running 28 vents. Pick up a set, as Phil said 32s are way to big.
What are your idle jets? You should be running 50s. Also you should be around 2 - 3 full turns out on the mixture screws. After that you should be driving to get a feel for it and the jets. Make sure all vac ports are blocked since you are running a 009. There might be one on the side of cylinder 4 carb barrel. Since you are running 009 you will have off idle stumble. Most people mask that with larger jets or more timing. The correct way to handle that is with the correct Dizzy, most cost effective one pertronix SVDA ($160) eliminates points and fixes off idle stumble in one unit. Also which snail did you get? It should be a German one around $45 |
Type 47 |
Apr 6 2023, 09:53 PM
You should be running 28 vents. Pick up a set, as Phil said 32s are way to big. What are your idle jets? You should be running 50s. Also you should be around 2 - 3 full turns out on the mixture screws. After that you should be driving to get a feel for it and the jets. Make sure all vac ports are blocked since you are running a 009. There might be one on the side of cylinder 4 carb barrel. Since you are running 009 you will have off idle stumble. Most people mask that with larger jets or more timing. The correct way to handle that is with the correct Dizzy, most cost effective one pertronix SVDA ($160) eliminates points and fixes off idle stumble in one unit. Also which snail did you get? It should be a German one around $45 the gauge is a Kuhlek Moterwerks I got from amazon I will check the jets tomorrow. |
Lo-Fi Version | Time is now: 6th January 2025 - 06:29 PM |
