Rear wheel bearing replacement, Parts needed? |
JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
Jeffs9146 |
Nov 14 2012, 01:14 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Just the bearing! (IMG:style_emoticons/default/beerchug.gif)
You might as well replace the bushings also while your in there!! |
DennisV |
Apr 11 2023, 04:17 PM
Senior Member Group: Members Posts: 532 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Superhawk996 |
Apr 11 2023, 06:16 PM
914 Guru Group: Members Posts: 6,464 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
You might as well replace the bushings also while your in there!! Can you please clarifying "bushings"? I'm sure it's obvious to someone with experience, but it's not to me. There's nothing in the diagram called "bushing". Thank you. @DennisV Reference is to the trailing arm rubber bushings |
Lo-Fi Version | Time is now: 16th September 2024 - 01:32 PM |
