> Safari 914 project, “Sufari”
East coaster
post Nov 4 2022, 08:04 PM
I’ve been out of the 914 game for quite some time. The last 914 I built was back in 2006 and was quite a build. I’ve had about a dozen 914s over the years and my 2006 build was to be my ultimate 914 (for me at least). It was a GT flared 3.6 six conversion and was a great car. I sold it in 2015 and moved to other things. I’ve been getting the itch to build another teener for a while, but to go in a different direction. I’ve seen a couple Safari builds and that seemed interesting.
I picked up pretty well worn ‘72 914 for the base of my project. My plan is to build a budget conscious (it’s all relative) Subaru powered Safari mod. I plan to go with a normally aspirated 2.5 Subaru from a 1998 Forrester along with the Subaru tranny.
I’ve been working on removing rust and getting the tub suitable for my plans. This will by no means be a concours resto type build, but should prove interesting.
Here’s the base car being picked up for the project start
I stripped it down and sold the engine and tranny (it was a partially completed V8 conversion). Then started cutting out rusted areas a welding in new metal.
Some Radom rust repair pics in no special order….
East coaster
post Apr 12 2023, 05:07 AM
Thanks for the kind words Chris. You’re one of the folks to blame when it came to choice of drivetrain (IMG:style_emoticons/default/wink.gif)
This is a pretty far departure from most builds, but I’m actually trying to do the safari mods so that it could be fairly easily put back to stock. Most of my mods either use stock mounting points, or at least leave stock mounting points intact. I’m pretty sure I’m going to enjoy the safari mods, along with Subaru drivetrain, but if someday post my ownership someone wanted to revert to stock it shouldn’t be too difficult.
Chris H.
post Apr 12 2023, 05:37 AM
QUOTE(East coaster @ Apr 12 2023, 06:07 AM) *
Guilty as charged sir (IMG:style_emoticons/default/biggrin.gif). You'll like the Subaru drive train. The engine mounts for most of them are the same configuration so in the future you can update/swap as needed with very little effort. Seems like you saved that car, which had the usual fixable rusty areas and mods for a V8 swap. Enjoy it! Hope to see it someday.
East coaster   Safari 914 project   Nov 4 2022, 08:04 PM
East coaster   [ Hell hole attachmentid=856763]   Nov 4 2022, 08:08 PM
East coaster   Closed up the tell tale V8 mod   Nov 4 2022, 08:11 PM
East coaster   And moved on to some suspension fun……aka Safar...   Nov 4 2022, 08:15 PM
waltonsm   And moved on to some suspension fun……aka Safa...   Nov 6 2022, 05:10 PM
East coaster   Working on the radiator install. I plan to vent ou...   Nov 4 2022, 08:18 PM
East coaster   Machined rear hubs and rotors for 5 lug…. Reb...   Nov 4 2022, 08:51 PM
Tjmrfe   Looks great. Looking forward to following your jou...   Nov 4 2022, 08:58 PM
mb911   Will you finishing the welds on the floor pan? Loo...   Nov 5 2022, 08:32 AM
East coaster   Will you finishing the welds on the floor pan? Lo...   Nov 6 2022, 06:21 AM
jhynesrockmtn   I don't get the safari trend thing but your sk...   Nov 5 2022, 09:11 AM
914sgofast2   I don't get the safari trend thing but your s...   Nov 5 2022, 02:42 PM
914e   I don't get the safari trend thing but your s...   Nov 5 2022, 03:08 PM
infraredcalvin   Do you really want a hole on the bottom of the car...   Nov 6 2022, 07:33 AM
East coaster   I guess I’ll see where I end up with camber. I s...   Nov 7 2022, 06:42 AM
East coaster   It was hood seal channel repair day. Bent some 18 ...   Nov 8 2022, 07:57 PM
bkrantz   Nice work! How high will the floor pan sit ab...   Nov 8 2022, 08:26 PM
r_towle   Good to see this one saved…it needed your skills...   Nov 9 2022, 08:06 AM
East coaster   Radiator time…..made a mount for the bottom of t...   Nov 12 2022, 08:35 PM
East coaster   Then moved on to a means of mounting the top of th...   Nov 12 2022, 08:36 PM
East coaster   A small diversion project to allow me to work in t...   Dec 4 2022, 07:39 AM
East coaster   Machined a conversion part for the clutch clevis. ...   Dec 7 2022, 07:08 AM
East coaster   With radiator mount completed, it was on to the fa...   Dec 15 2022, 07:36 PM
East coaster   RE: Safari 914 project   Dec 15 2022, 07:38 PM
East coaster   Purdy……   Dec 15 2022, 07:39 PM
Montreal914   I am still in admiration with your fiberglass duct...   Dec 15 2022, 09:33 PM
East coaster   I am still in admiration with your fiberglass duc...   Dec 16 2022, 06:06 AM
Blue6   I am still in admiration with your fiberglass duc...   Dec 15 2022, 09:49 PM
slowrodent   Super metal fab work.. And that plenum is wondrous...   Dec 16 2022, 07:53 AM
Retroracer   Another nod to the excellent footwear - but adding...   Dec 16 2022, 10:35 AM
East coaster   Another nod to the excellent footwear - but addin...   Dec 16 2022, 07:35 PM
East coaster   Finished up the entrance plenum. Final fitting/tri...   Dec 20 2022, 06:30 PM
East coaster   Surfing through a sea of wires………I plan to u...   Jan 29 2023, 09:28 PM
East coaster   I tore down my donor Suby engine and replaced head...   Feb 7 2023, 07:08 PM
East coaster   While the engine was upside down, I started fabric...   Feb 7 2023, 07:14 PM
raynekat   Nice welds there...you've definitely got...   Feb 19 2023, 11:20 PM
East coaster   Nice welds there...you've definitely got som...   Feb 20 2023, 07:01 PM
East coaster   Couple more pics….   Feb 7 2023, 07:15 PM
East coaster   Got more done on the cradle today. Bent some 1-1/2...   Feb 10 2023, 07:58 PM
East coaster   Fabricated the trans support and incorporated the ...   Feb 13 2023, 08:16 PM
East coaster   Took advantage of some unseasonable February weath...   Feb 17 2023, 06:39 PM
East coaster   My focus on my project has been all over the map, ...   Feb 19 2023, 07:44 PM
euro911   Cool :headbanger:   Feb 20 2023, 06:45 PM
rgalla9146   You're in Brigantine, I'm in Paramus W...   Feb 21 2023, 10:45 AM
East coaster   You're in Brigantine, I'm in Paramus ...   Feb 21 2023, 06:20 PM
East coaster   RE: Safari 914 project   Feb 22 2023, 06:54 PM
East coaster   Began fabricating my alternator bracket today. It...   Feb 25 2023, 08:40 PM
East coaster   First test fit of the engine/trans. Everything fit...   Feb 26 2023, 06:29 PM
East coaster   Finalized alignment of alternator bracket and fini...   Feb 28 2023, 07:23 PM
East coaster   Worked out the engine harness today. I had to undr...   Mar 2 2023, 08:29 PM
East coaster   Started fabricating my safari rack (what’s a saf...   Mar 5 2023, 07:58 PM
East coaster   Decided to lower the rear control arm mounts to ac...   Mar 9 2023, 08:27 PM
East coaster   Then I re-attached the box section removed in 1st ...   Mar 9 2023, 08:31 PM
East coaster   Then I cleaned up and drilled a new mounting hole ...   Mar 9 2023, 08:35 PM
East coaster   The outer trailer trailing arms spacers are done...   Mar 10 2023, 08:20 PM
Retroracer   Some great fabrication there. Rack design coming ...   Mar 11 2023, 09:21 AM
East coaster   Some great fabrication there. Rack design coming...   Mar 11 2023, 09:04 PM
East coaster   Trailing arms installed and its back on its feet...   Mar 11 2023, 09:07 PM
East coaster   Somethin’ brewin’…….   Mar 14 2023, 07:09 PM
East coaster   Picked up a stock front valance in nice shape and ...   Mar 15 2023, 07:54 PM
East coaster   Did the same treatment to the bumper…….radiato...   Mar 23 2023, 07:52 AM
East coaster   I saved the sh*ttiest task for last……had to re...   Mar 23 2023, 06:47 PM
East coaster   Patch welded in…..   Mar 23 2023, 06:50 PM
East coaster   Passenger side was worse and required 2 patch piec...   Mar 23 2023, 06:51 PM
East coaster   Then it was on to rear trunk hinge pivots. The dri...   Mar 23 2023, 06:58 PM
East coaster   Tackled the battery tray next. Although I’m doin...   Mar 24 2023, 05:28 AM
East coaster   Decided a little while back to go with 911 struts....   Mar 24 2023, 07:51 PM
East coaster   Safari stuff progress……still have to work the ...   Mar 27 2023, 08:08 PM
East coaster   Miscellaneous tidbits…..   Mar 31 2023, 06:58 PM
East coaster   RE: Safari 914 project   Mar 31 2023, 07:01 PM
Retroracer   Hinged at the front so you can remove the targa ro...   Apr 1 2023, 09:48 AM
East coaster   Hinged at the front so you can remove the targa r...   Apr 1 2023, 07:10 PM
slowrodent   This is such a BOLD build . I really do love it. Y...   Apr 2 2023, 01:01 PM
sixnotfour   Better reinforce windshield frame.. https://pbase...   Apr 2 2023, 01:01 PM
East coaster   Better reinforce windshield frame.. https://pbas...   Apr 2 2023, 06:12 PM
East coaster   My biggest challenge in this project thus far is d...   Apr 2 2023, 06:37 PM
East coaster   Started work on the rear rack. Hope to get it weld...   Apr 3 2023, 07:00 PM
Optimusglen   This is giving me ideas, love the build so much. I...   Apr 3 2023, 07:22 PM
East coaster   Looks very cool.   Apr 4 2023, 05:18 AM
altitude411   * Subscribed... very cool build. Thank you for pos...   Apr 4 2023, 09:00 AM
Van914   Saw this one in Indy a few years ago   Apr 4 2023, 04:37 PM
East coaster   Finished fabricating and welding the rear rack. On...   Apr 4 2023, 07:56 PM
East coaster   Finished the rear cargo rack and got it mounted to...   Apr 6 2023, 08:08 PM
East coaster     Apr 6 2023, 08:09 PM
wonkipop   love the trunk lid hinging. :beer2:   Apr 6 2023, 08:44 PM
Optimusglen   Do you need a winch to lift the rear trunk? :D ki...   Apr 7 2023, 08:10 AM
East coaster   Do you need a winch to lift the rear trunk? :D k...   Apr 7 2023, 07:27 PM
Shivers   Well, this rocks (pun intended}. The rack sure mak...   Apr 7 2023, 09:10 AM
Montreal914   Very nice work! :) Based on the quality of ...   Apr 7 2023, 08:27 PM
East coaster   Installed gas struts for the rear trunk today. The...   Apr 8 2023, 07:15 PM
East coaster   Decided to go with something different for my head...   Apr 10 2023, 07:41 PM
brubou   Forget Cibie's!!! Mount a couple 9...   Apr 10 2023, 08:30 PM
Retroracer   Cool idea with the fixed 928 headlight buckets. C...   Apr 11 2023, 08:43 AM
East coaster   A few detail pics of headlight framing…..   Apr 11 2023, 08:07 PM
East coaster   More….   Apr 11 2023, 08:08 PM
East coaster   RE: Safari 914 project   Apr 11 2023, 08:09 PM
Chris H.   Your fab skills are really next level. You're...   Apr 12 2023, 04:43 AM
East coaster   Thanks for the kind words Chris. You’re one of t...   Apr 12 2023, 05:07 AM
Chris H.   Thanks for the kind words Chris. You’re one of ...   Apr 12 2023, 05:37 AM
East coaster   Got the mounts figured out for my coolant expansio...   Apr 13 2023, 07:32 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 2nd April 2025 - 03:07 AM
