emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
I am having a very specific issue here. Pump no longer holds pressure after shutdown. Original location, original three port pump. It still pumps great when running, but no longer holds pressure. Need to fix that and quick. Do I have to replace it or can it be repaired?
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Why do you need to have the pressure hold when the engine is shut off?
Maybe its something I don't understand. when I replaced my fuel pump, (Bosch 044) it came with a check valve that I removed. I did not see a need to have pressure on the injectors when the engine is not running. It always drops to zero when I shut it off. never have a problem starting up. have since replaced that pump with a quieter pump (Bosch 69133) that does not have a check valve. still starts right up on first turn of the key. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:28 PM |
