intermittent starter or ignition issue?, where to look next? |
DRPHIL914 |
Apr 28 2023, 08:07 PM
Dr. Phil Group: Members Posts: 5,813 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
So this issue has happened 3x now in the past few months, and now today after driving 300 miles up to Brevard, NC on the way , stopped to get gas, going to start it, no crank. all other electronics work, fuel pump priming just no starter engagement. it’s happened cold too, i can get it to start by push start.. so about an hour ago i pulled the steering wheel and replaced the plastic switch still no starter , i also checked the yellow wires under passenger seat (seat buzzer by-pass) , i don’t think that’s the issue.
I bought and installed a new Bosch starter about 6 months ago and installed it on this newer motor a few months back, so now i am wondering if it’s a bad solenoid? wond not crank . the last time it happened was a months ago, push start got me home from the store, and when i got home and pulled into the garage after turning it off it started right back up and has for the next 10 times —- until tonight. what are the other possibilities? does the power go from the ignition switch to the relay board and then to the starter? i have done a few searches , but looking for someone that’s maybe had this issue or understands the whole schematic better . i don’t have a multimeter with me but i can get one tomorrow at O’Reilly’s and i might see if they can get a starter., i’m just guessing and grasping at straws .. - oh, for those that don’t know it’s a ‘75 2056 d-jet. Phil |
dr914@autoatlanta.com |
Apr 29 2023, 09:36 AM
914 Guru Group: Members Posts: 8,132 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if the car will not engage the starter when hot and you have a new bosch starter, first check the yellow lead at the solenoid for power and then check for voltage. If the voltage is down you can install a wr1 bosch relay kit. Also check the neg battery to firewall ground and the trans rear cover to bottom of the trunk floor ground
So this issue has happened 3x now in the past few months, and now today after driving 300 miles up to Brevard, NC on the way , stopped to get gas, going to start it, no crank. all other electronics work, fuel pump priming just no starter engagement. it’s happened cold too, i can get it to start by push start.. so about an hour ago i pulled the steering wheel and replaced the plastic switch still no starter , i also checked the yellow wires under passenger seat (seat buzzer by-pass) , i don’t think that’s the issue. I bought and installed a new Bosch starter about 6 months ago and installed it on this newer motor a few months back, so now i am wondering if it’s a bad solenoid? wond not crank . the last time it happened was a months ago, push start got me home from the store, and when i got home and pulled into the garage after turning it off it started right back up and has for the next 10 times —- until tonight. what are the other possibilities? does the power go from the ignition switch to the relay board and then to the starter? i have done a few searches , but looking for someone that’s maybe had this issue or understands the whole schematic better . i don’t have a multimeter with me but i can get one tomorrow at O’Reilly’s and i might see if they can get a starter., i’m just guessing and grasping at straws .. - oh, for those that don’t know it’s a ‘75 2056 d-jet. Phil |
Lo-Fi Version | Time is now: 30th January 2025 - 08:42 PM |
