> intermittent starter or ignition issue?, where to look next?
DRPHIL914
post Apr 28 2023, 08:07 PM
Dr. Phil
So this issue has happened 3x now in the past few months, and now today after driving 300 miles up to Brevard, NC on the way , stopped to get gas, going to start it, no crank. all other electronics work, fuel pump priming just no starter engagement. it’s happened cold too, i can get it to start by push start.. so about an hour ago i pulled the steering wheel and replaced the plastic switch still no starter , i also checked the yellow wires under passenger seat (seat buzzer by-pass) , i don’t think that’s the issue.
I bought and installed a new Bosch starter about 6 months ago and installed it on this newer motor a few months back, so now i am wondering if it’s a bad solenoid? wond not crank . the last time it happened was a months ago, push start got me home from the store, and when i got home and pulled into the garage after turning it off it started right back up and has for the next 10 times —- until tonight.
what are the other possibilities? does the power go from the ignition switch to the relay board and then to the starter? i have done a few searches , but looking for someone that’s maybe had this issue or understands the whole schematic better . i don’t have a multimeter with me but i can get one tomorrow at O’Reilly’s and i might see if they can get a starter., i’m just guessing and grasping at straws ..
- oh, for those that don’t know it’s a ‘75 2056 d-jet.
Phil
mgphoto
post Apr 29 2023, 08:55 AM
"If there is a mistake it will find me"
Bosch Brazilian solenoids last about 6 months, that’s what they use for all rebuilt units, I went to the hi torq Toyota starter about 2 years ago, no problem whatsoever, very simple to rebuild too.
DRPHIL914
post Apr 29 2023, 09:37 AM
Dr. Phil
QUOTE(mgphoto @ Apr 29 2023, 10:55 AM) *
do you know part # for the toyota starter? i just checked with local Flaps and i can have a 914 bosch starter here from them at 3pm- i’ll try the screw driver trick for dx after this show is complete
some beautiful cars here today! over 350 porchche only 2 914’s!
DRPHIL914   intermittent starter or ignition issue?   Apr 28 2023, 08:07 PM
76-914   So this issue has happened 3x now in the past few...   Apr 28 2023, 08:15 PM
DRPHIL914   So this issue has happened 3x now in the past fe...   Apr 28 2023, 08:50 PM
Superhawk996   Use screwdriver to short between the 12v positive ...   Apr 28 2023, 10:13 PM
emerygt350   And the ford solenoid fix is so easy it's fun....   Apr 29 2023, 04:41 AM
jim_hoyland   Will the car push-start ?   Apr 29 2023, 06:12 AM
technicalninja   If you have a degraded signal coming to the soleno...   Apr 29 2023, 06:26 AM
mgphoto   Bosch Brazilian solenoids last about 6 months, tha...   Apr 29 2023, 08:55 AM
DRPHIL914   Bosch Brazilian solenoids last about 6 months, th...   Apr 29 2023, 09:37 AM
mgphoto   [quote name='mgphoto' post='3074608' date='Apr 29...   Apr 29 2023, 06:02 PM
dr914@autoatlanta.com   if the car will not engage the starter when hot an...   Apr 29 2023, 09:36 AM
DRPHIL914   if the car will not engage the starter when hot a...   Apr 29 2023, 10:52 AM
Superhawk996   1/2 split - don’t guess randomly If you want to...   Apr 29 2023, 11:26 AM
r_towle   yellow wire under the passenger seat... Is it stil...   Apr 29 2023, 12:35 PM
Superhawk996   the old wiring we have gets corroded inside, thu...   Apr 29 2023, 01:04 PM
r_towle   the old wiring we have gets corroded inside, th...   Apr 29 2023, 01:28 PM
Superhawk996   [quote name='Superhawk996' post='3074634' date='A...   Apr 29 2023, 02:08 PM
technicalninja   I'm a huge fan of extra grounds as well. I re...   Apr 29 2023, 01:21 PM
r_towle   I'm a huge fan of extra grounds as well. I r...   Apr 29 2023, 01:32 PM
emerygt350   Did I mention the ford solenoid is a fun and easy ...   Apr 29 2023, 05:00 PM
DRPHIL914   i used the screw driver trick, and right after tha...   Apr 29 2023, 06:53 PM
Superhawk996   i used the screw driver trick, and right after th...   Apr 29 2023, 07:06 PM
DRPHIL914   i used the screw driver trick, and right after t...   May 1 2023, 07:59 AM
Superhawk996   as you all know pretty hard to get under a 914 w...   May 1 2023, 08:05 AM
jim_hoyland   In So Cal, Oscar's on 17th Street in Costa Mes...   May 1 2023, 05:18 AM
DRPHIL914   nice shop , more of a “garage mahal” a recent...   May 1 2023, 08:04 AM
- Lo-Fi Version Time is now: 30th January 2025 - 08:24 PM
