> 123 Distributor Group Buy, Discount to May 6, 2023
gonzo54
post Apr 5 2023, 06:02 PM
Orange Crush
I talked to Ed Madak at 123 Ignition USA today and he has provided us with a discount code good for 914 World Members as follows:
"Hi Rick
CODE: 914World23
Thanks for the business. Here is your coupon code it is case sensitive. Effective immediately at 5%. I will keep an eye on the progress for you. When we reach 10 the discount will be 10% and anyone who has placed an order will be refunded the difference.
They will just need to enter the code at checkout to receive the discount. The expiration date is May 6th 2023
Ed was very helpful directing me the the 123 distributor that will work best on my car.
Website for ordering: 123ignitionusa
Ed Madak 440 668-8164
I almost forgot to add that this discount code is good for any make and model car you have.
Update 4/28/23 - 10 members have purchased a 123 distributor - the 10% discount code will apply to everyone!
NJ914
post May 4 2023, 10:49 AM
Ed,
Appreciate your inputs on this Chart. The bottom of the chart is cut off and states:
"All but the first two and the last single entry were taken from tables in the factory manual. The others were taken from graphs in the factory manual. The advance curves on the graphs for those first two distributors start at 5 degrees, and increase by 11-15 degrees. Likewise the retard curves start at +5 degrees (advanced) and decrease by 8-10 degrees. However, the last [2.0] graph starts both the advance and retard curves from zero degrees.
So a note about "Total advance or retard is relative to the timing with no vacuum" or something to that effect is probably in order."
This is where I found it:
http://web.archive.org/web/20030202024600/...ww.dgi.net/914/
Would really like your inputs on the programming of my 039 905 205B (which I'm guessing is the last row for the 2.0 noted unlabeled. (It is almost the same as the 205A above it anyway.)
Based on the 123 dist instructions, these points need to be doubled (assuming the chart is based on distributor rpm and not crankshaft).
Centrifugal:
0 deg @ 900rpm becomes 0 deg @ 1800rpm
9 deg @ 1500rpm becomes 18 deg @ 3000rpm
15 deg @ 2000rpm becomes 30 deg @ 4000rpm
22 deg @ 2800rpm becomes 44 deg @ 5600rpm
Vacuum:
0 deg @ 108mmHg becomes 0 deg @ 15kPa and finally 0 deg @ (100-15) 85kPa
7 deg @ 125mmHg becomes 14 deg @ 17kPa and finally 14 deg @ (100-17) 83kPa
Does this sound right to you?
Would really appreciate your inputs...
WARNING: Too many @ tags!
123ignitionusa
post May 4 2023, 12:05 PM
QUOTE(NJ914 @ May 4 2023, 12:49 PM) *
Ed,
Centrifugal:
Vacuum:
I might be concerned about the all in number of 44 degrees. But only because I know nothing about your cars and what they should be running all in and at how many rpm.
So first thing to do is confirm whether the chart is crankshaft or distributor degrees.
In my opinion, (which doesn't mean much) normally some timing is needed at start up.
In the British car world the starting sweetspot is usually somewhere between 12 and 17 degrees.
Your manual should tell you if they are referring to distributor degrees or crankshaft degrees. We always refer to crankcase degrees which are double the distributor degrees.
As for the Vacuum I would not use vacuum retard only vacuum advance. Normally the map curve in the app is good and adds 10 degrees when the inches of mercury call for it. You could make that value whatever you like.
Gatornapper
post May 4 2023, 07:23 PM
Ed -
Did I get the right dizzy? Weber's now, D-Jet in fall? What about vacuum? Forgot to ask you about that..
GN
aka Richard Hanes
QUOTE(123ignitionusa @ May 4 2023, 12:05 PM) *
Ed,
Centrifugal:
Vacuum:
gonzo54   123 Distributor Group Buy   Apr 5 2023, 06:02 PM
jim_hoyland   See: https://123ignitionusa.com/   Apr 6 2023, 06:34 AM
Nacho   I talked to Ed Madak at 123 Ignition USA today an...   Apr 6 2023, 11:42 AM
Nacho   [quote name='gonzo54' post='3069872' date='Apr 5 ...   Apr 6 2023, 11:53 AM
gonzo54   [quote name='gonzo54' post='3069872' date='Apr 5 ...   Apr 6 2023, 01:28 PM
Nacho   Just placed my order with ED @ 123 Distributor :Q...   Apr 6 2023, 12:02 PM
jim_hoyland   Just placed my order with ED @ 123 Distributor :...   Apr 6 2023, 05:19 PM
Nacho   Just placed my order with ED @ 123 Distributor ...   Apr 6 2023, 05:28 PM
gonzo54   Just ordered my 123 Bluetooth BT Tune+ 4-R-V-Por-I...   Apr 7 2023, 04:37 PM
gonzo54   My 123 wireless programable distributor should arr...   Apr 10 2023, 07:15 AM
NJ914   Just ordered my Bluetooth Programable 123 Distribu...   Apr 10 2023, 12:36 PM
gonzo54   Just ordered my Bluetooth Programable 123 Distrib...   Apr 10 2023, 06:32 PM
Type 47   I had some questions but Ed was not able to call m...   Apr 11 2023, 03:01 PM
gonzo54   I had some questions but Ed was not able to call ...   Apr 11 2023, 05:26 PM
NJ914   My 123 distributor (DJet Bluetooth) is due today a...   Apr 13 2023, 11:10 AM
Type 47   My 123 stuff (L-Jet for Webers) was also due to ar...   Apr 14 2023, 03:50 PM
gonzo54   My 123 stuff (L-Jet for Webers) was also due to a...   Apr 15 2023, 07:58 AM
mmascari   Wow, talk about good timing. I have my car at my ...   Apr 15 2023, 08:40 AM
Type 47   Wow, talk about good timing. I have my car at my...   Apr 15 2023, 12:15 PM
gonzo54   I talked to Ed Madak at 123 Ignition USA today and...   Apr 18 2023, 09:04 AM
914_teener   Wow...I started that thread. 2017 was a good year ...   Apr 18 2023, 09:19 AM
gonzo54   Wow...I started that thread. 2017 was a good year...   Apr 18 2023, 02:48 PM
mmascari   Does anyone know where you can find the timing cur...   Apr 18 2023, 10:15 AM
nditiz1   Does anyone know where you can find the timing cu...   Apr 18 2023, 03:26 PM
JORACER#40   Only for the 6? I have 4 2.0L and am also looking ...   Apr 20 2023, 09:15 PM
gonzo54   Less than 2 weeks left for the Group Buy Discount....   Apr 25 2023, 06:56 AM
Gatornapper   I'm IN! Hoping we get 10 on board for thi...   Apr 25 2023, 07:27 AM
gonzo54   I'm IN! Hoping we get 10 on board for th...   Apr 25 2023, 07:55 AM
Gatornapper   Talked to Ed - just completed order. With this la...   Apr 25 2023, 08:12 AM
gonzo54   Ed at 123 Ignition USA updated the 914 Group Buy a...   Apr 26 2023, 09:06 AM
mmascari   I just made my purchase this morning, so hopefully...   Apr 26 2023, 09:07 AM
gonzo54   I just made my purchase this morning, so hopefull...   Apr 26 2023, 10:13 AM
flipb   I'll admit, I'm tempted. I'm running...   Apr 26 2023, 02:54 PM
gonzo54   I'll admit, I'm tempted. I'm runnin...   Apr 26 2023, 03:02 PM
sportlicherFahrer   Finally pulling the trigger on one of these. Gues...   Apr 26 2023, 04:29 PM
Puebloswatcop   Will definately be purchasing one after my payday ...   Apr 26 2023, 05:07 PM
gonzo54   Will definately be purchasing one after my payday...   Apr 27 2023, 01:14 PM
porscheteck914   Will definately be purchasing one after my payda...   Apr 27 2023, 01:50 PM
gonzo54   [quote name='gonzo54' post='3074222' date='Apr 27...   Apr 27 2023, 02:56 PM
sportlicherFahrer   I would probly get one ... but I dont know which...   Apr 27 2023, 02:11 PM
Dlee6205   Just ordered one for my build. :Qarl: I'v...   Apr 27 2023, 02:41 PM
jvmarino   It was a bit tough for me to spend this much on a ...   Apr 28 2023, 01:38 PM
Type 47   :Qarl: :trophy: :beer1:   Apr 28 2023, 03:05 PM
gonzo54   Ed Madak at 123 Ignition USA just confirmed that w...   Apr 28 2023, 04:31 PM
Type 47   Can someone post an image of what their curves loo...   Apr 28 2023, 07:03 PM
gonzo54   This is the last week of the Group Buy-   Apr 30 2023, 06:43 AM
Chris H.   Wonder if this would work well on a 1.9l Vanagon ...   Apr 30 2023, 07:36 AM
gonzo54   Wonder if this would work well on a 1.9l Vanagon ...   Apr 30 2023, 10:58 AM
Chris H.   Wonder if this would work well on a 1.9l Vanagon...   May 3 2023, 06:12 AM
NJ914   Just installed my new programable 123 Distributor ...   May 1 2023, 11:50 AM
Gatornapper   NJ - Please send me the curve when you get it. G...   May 4 2023, 07:19 PM
JORACER#40   I also need the curves for a 74 2.0L and 76 2.0L ...   May 1 2023, 03:17 PM
NJ914   I found this but not sure where it came from....? ...   May 2 2023, 07:01 AM
JORACER#40   I found this but not sure where it came from....?...   May 3 2023, 08:03 PM
Puebloswatcop   Just ordered mine too. Had a question so called E...   May 3 2023, 04:55 PM
123ignitionusa   I want to thank all of you for supporting 123ignit...   May 4 2023, 09:28 AM
123ignitionusa   Re Vanagon Couple of things to find out. Is it car...   May 4 2023, 09:44 AM
NJ914   Ed, Appreciate your inputs on this Chart. The bo...   May 4 2023, 10:49 AM
123ignitionusa   Ed, Appreciate your inputs on this Chart. The b...   May 4 2023, 12:05 PM
Gatornapper   Ed - Did I get the right dizzy? Weber's now,...   May 4 2023, 07:23 PM
123ignitionusa   Hi Richard My records show you should have the TUN...   May 5 2023, 07:45 AM
Gatornapper   Ed - sent PM. GN   May 5 2023, 07:56 AM
NJ914   Richard: I plan on going through the curves etc t...   May 5 2023, 10:30 AM
JORACER#40   Just purchased Now the fun begins Ed has been very...   May 5 2023, 03:27 PM
123ignitionusa   If you didn't erase the curve on the distribut...   May 5 2023, 09:37 PM
jcd914   Here are some advance curce specs I found that are...   May 6 2023, 12:19 PM
jvmarino   Just installed my BT model. I have a 2.0 with ori...   May 6 2023, 06:47 PM
swood   I’ve been off the board awhile and this distribu...   May 14 2023, 10:41 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:22 PM
