Fuel tank venting |
Fuel tank venting |
FJ1200 |
May 16 2023, 08:49 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Morning,
I think its finally time to address the fuel smell on my 72. I pulled the tank last night and it looks like the tank was probably replaced at some point as it is near perfect. I ordered new stainless tunnel lines from Chris Foley as well as new hoses and clamps for both ends. My question is venting. There is literally no hoses left in the frunk. It looks like the 3mm lines should all tee together and tie to the charcoal canister. So 2 ports on the expansion tank, 1 port on the filler neck and the then the canister. Is this right? If so then I should need 2 tee's. The overflow hose looks like it is currently NA, 914 rubber is out of stock as are other vendors. Has anyone used 3/4" clear poly tubing in its place? Lastly after I hookup the canister does anyone offer a clean looking solution to tie the suction side into IDF air filters? Thanks. |
mgphoto |
May 16 2023, 11:28 AM
"If there is a mistake it will find me" Group: Members Posts: 1,364 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Lo-Fi Version | Time is now: 1st November 2024 - 06:13 AM |
