> Fuel tank venting
FJ1200
post May 16 2023, 08:49 AM
Morning,
I think its finally time to address the fuel smell on my 72. I pulled the tank last night and it looks like the tank was probably replaced at some point as it is near perfect. I ordered new stainless tunnel lines from Chris Foley as well as new hoses and clamps for both ends. My question is venting. There is literally no hoses left in the frunk. It looks like the 3mm lines should all tee together and tie to the charcoal canister. So 2 ports on the expansion tank, 1 port on the filler neck and the then the canister. Is this right? If so then I should need 2 tee's. The overflow hose looks like it is currently NA, 914 rubber is out of stock as are other vendors. Has anyone used 3/4" clear poly tubing in its place? Lastly after I hookup the canister does anyone offer a clean looking solution to tie the suction side into IDF air filters?
Thanks.
FJ1200
post May 16 2023, 03:36 PM
@914sgofast2
Everything you posted seems rights. There is minimal surface rust at the 4 points that contact the felt pads. I gave them a quick rub with a scotch brite and the steel is solid.
I think I have my answers, I need to put in an order with Belmetric and Autoatlanta and I think I'll have everything I need to put the system into a functional condition.
Thanks everyone,
FJ1200   Fuel tank venting   May 16 2023, 08:49 AM
FJ1200   Forgot to mention, if anyone has a picture of how ...   May 16 2023, 08:54 AM
Steve   Just depends on if you want the factory setup or s...   May 16 2023, 09:18 AM
FJ1200   So the PET is misleading, looks like the breather ...   May 16 2023, 09:33 AM
r_towle   the pipes or tubes go down the drivers side behind...   May 16 2023, 10:44 AM
FJ1200   r towle Everything you say makes sense, i agree w...   May 16 2023, 11:08 AM
mgphoto   I did this years ago and no trouble since. http:/...   May 16 2023, 11:28 AM
914sgofast2   Are you sure the gas tank does not have surface ru...   May 16 2023, 12:31 PM
FJ1200   @914sgofast2 Everything you posted seems rights....   May 16 2023, 03:36 PM
Quinn Moore   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 28 2024, 10:23 AM
ClayPerrine   I realize this is an older post. I've been s...   Jun 28 2024, 11:29 AM
Quinn Moore   I realize this is an older post. I've been ...   Jun 28 2024, 12:41 PM
ClayPerrine   [quote name='ClayPerrine' post='3153690' date='Ju...   Jun 29 2024, 06:12 AM
JamesM   Morning, I think its finally time to address the...   Jun 29 2024, 12:18 PM
Quinn Moore   Morning, I think its finally time to address th...   Jun 30 2024, 10:39 AM
914werke   I realize this is an older post. I've been se...   Jun 30 2024, 12:27 PM
Quinn Moore   I realize this is an older post. I've been s...   Jun 30 2024, 01:09 PM
willieg   Morning, I think its finally time to address the...   Jun 30 2024, 01:45 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 1st November 2024 - 06:13 AM
