Mysterious Plug, What's black and red and hides under carpet? |
DennisV |
Jun 2 2023, 06:03 PM
Senior Member Group: Members Posts: 551 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Am I correct in assuming that this has no business in a 1970 914-6? There was nothing attached to the plug which was near the base of the shifter. It looks homemade, with a fuse inline.
I tried finding a color wiring diagram for a 914-6. I kicked up a few names in searches, but none of them replied to me about buying one. |
windforfun |
Jun 2 2023, 07:16 PM
Senior Member Group: Members Posts: 1,985 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Neither one is stock. It's a DAPO thing.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
peteyd |
Jun 6 2023, 11:01 AM
Senior Member Group: Members Posts: 730 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Neither one is stock. It's a DAPO thing. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Wrong... the brown/white on the tunnel is most likely the fan switch. Cavity 9 on 14 pin connector that plugs into the relay panel in the engine bay the inline fuse is an addition from a previous owner. Please give informed advice. Pete |
DennisV |
Jun 7 2023, 07:13 AM
the brown/white on the tunnel is most likely the fan switch. Cavity 9 on 14 pin connector that plugs into the relay panel in the engine bay the inline fuse is an addition from a previous owner. Please give informed advice. Thank you for chiming in Pete. Where is that spade connector meant to attach? I'm not seeing an obvious mate for it. I assume it's opposite end is running to the position you reference in the engine bay. |
Lo-Fi Version | Time is now: 28th November 2024 - 04:39 AM |
