porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Have a 911 temp insert I'am fitting to a 914 fuel gauge,I have 2 inserts but only one works but connecting power and earth to battery,needle go's straight to full reading is that correct ?.
If thats correct I want to test with sender,presuming if I connect sender to "G" on the rear of the gauge and earth the body of sender before applying heat to it ?. This isn't going in my car as I have all the 911 gauges sorted in my "6" conversion but a good winter project inside with the heating on (IMG:style_emoticons/default/biggrin.gif) . TIA ,cheers. ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Sounds correct so far. I've known a few folks that put a temp sender in boiling water to check the gauge.
I haven't had a temp gauge ever partially go bad on me. It's always the sender that seems to fail. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:07 AM |
