peteinjp |
Member ![]() ![]() Group: Members Posts: 211 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None ![]() ![]() |
Its not a huge deal to separate the hoses but if changing the oil often it would be nice to plumb in a valve or some type of plug to reduce long term wear on the hose seal. Anyone done this? Or any other thoughts?
Pete |
Biggles |
Member ![]() ![]() Group: Members Posts: 200 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
Definitely recommend doing this in terms of the time saving and preventing the risk of putting any stress on the weld to the engine oil coller in removing the pipes (which was my previous experience).
Mine's a 3.2 with a termostat to the front cooler, but pics show the old set up (with annotations) and new set up with the 3 way ball valve installed (threaded brass plug to the drain hole is not shown as fitted in photo but obv. should be) on the line to the engine cooler. Only issue too with a front oil cooler, as per this set up, is that you can never fully drain the system towards the front, not an issue with regular oil changes. Attached thumbnail(s) ![]() ![]() ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,797 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Definitely recommend doing this in terms of the time saving and preventing the risk of putting any stress on the weld to the engine oil coller in removing the pipes (which was my previous experience). Mine's a 3.2 with a termostat to the front cooler, but pics show the old set up (with annotations) and new set up with the 3 way ball valve installed (threaded brass plug to the drain hole is not shown as fitted in photo but obv. should be) on the line to the engine cooler. Only issue too with a front oil cooler, as per this set up, is that you can never fully drain the system towards the front, not an issue with regular oil changes. That is a nice setup!! Where did you find/purchase the valve and "T" from? It's much cleaner than my AN16 "T" and cap. |
Biggles |
Definitely recommend doing this in terms of the time saving and preventing the risk of putting any stress on the weld to the engine oil coller in removing the pipes (which was my previous experience). Mine's a 3.2 with a termostat to the front cooler, but pics show the old set up (with annotations) and new set up with the 3 way ball valve installed (threaded brass plug to the drain hole is not shown as fitted in photo but obv. should be) on the line to the engine cooler. Only issue too with a front oil cooler, as per this set up, is that you can never fully drain the system towards the front, not an issue with regular oil changes. That is a nice setup!! Where did you find/purchase the valve and "T" from? It's much cleaner than my AN16 "T" and cap. Steve. I had some engine work done and the garage did this at the same time. Just google 3 way ball valve. That'll give a good starting point. Dont think its anything special. |
Lo-Fi Version | Time is now: 5th February 2025 - 06:54 AM |
