Autox tire choices |
jmargush |
Jun 20 2023, 08:50 AM
Member Group: Members Posts: 465 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am in need of new autox tires and the offerings have changed a bit since I last bought a set.
I am curious as to what people are running?, what do you like? is there a good trade off cost/performance? I will be mounting them on 15x6 cookie cutters |
mskala |
Jun 21 2023, 11:59 AM
R Group: Members Posts: 1,926 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
What are the limits for your car's class - diameter/width/treadwear-rating/etc ?
jmargush |
Jun 21 2023, 05:24 PM
What are the limits for your car's class - diameter/width/treadwear-rating/etc ? Small region pca rules and i am in improved class so not much in the way of limits via rules. But I can't run a tire larger than 205/50 15 due to wheels. Sometimes it might be nice to run a 195/60 or 205/60 for taller gearing |
Driver174 |
Jun 23 2023, 08:59 AM
Member Group: Members Posts: 108 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
What are the limits for your car's class - diameter/width/treadwear-rating/etc ? Small region pca rules and i am in improved class so not much in the way of limits via rules. But I can't run a tire larger than 205/50 15 due to wheels. Sometimes it might be nice to run a 195/60 or 205/60 for taller gearing What class do you plan to run? Street classes with 200 tread ware? Bridgestone RE71R is currently the best choice for 200 tw. |
jmargush |
Jun 24 2023, 04:01 AM
What are the limits for your car's class - diameter/width/treadwear-rating/etc ? Small region pca rules and i am in improved class so not much in the way of limits via rules. But I can't run a tire larger than 205/50 15 due to wheels. Sometimes it might be nice to run a 195/60 or 205/60 for taller gearing What class do you plan to run? Street classes with 200 tread ware? Bridgestone RE71R is currently the best choice for 200 tw. Thanks, that is good to know. I am more than likely going for a DOT R tire. |
Lo-Fi Version | Time is now: 22nd November 2024 - 07:10 AM |
