> Bus 4 spd trans, Anybody done this
jwalters
post Jan 21 2005, 06:38 PM
Sooo Close.......
Region Association: Europe
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Thought of an interesting topic---has anybody put a beefed up bus or t1 trans in the teener----
I loved the gear spacing on my old superbug--and first gear for my car,,well,,,sucks ass--and second is too tall for a good start off--
Would rather spend 650 bucks on a pro-streeter WITH a rhino case and super diff than thousands upgrading my 901--
Sand rail mid engine cable shifter should be able to be adapted rather easily and the trans install is a non-event...
What you think???? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Tom Perso
post Jan 22 2005, 06:43 PM
Crazy from the Cold...
I had a Rancho IRS trans in my Bug with a 2270cc T4 motor. It had a 3.88 R/P and a bus 4th gear and it cruised on the highway at 75 running 3500rpm (195/65's on the back). It also had the SB mainshafts, yada yada yada. It was build for Shad Law's 2615cc (80mm x 102) Nikkies equipped motor in his T4 before he went with a 915 from a 912.
To bolt a T4 to an IRS trans you need a 210 or 215 mm bus flywheel with the center opened up to hold a T1 input shaft bearing. I had my flywheel EDM'd out to press in the bearing.
(IMG:http://www.qtm.net/~persoj/graphics/vw/flywheel_bushing.jpg)
Then I ran the corresponding bus clutch and a KEP Gold 200mm T1 disc. Held the 2270 no problem.
It was no more expensive than doing a decent clutch job on a bug... No expensive conversion flywheels needed.
Later,
Tom
jwalters   Bus 4 spd trans   Jan 21 2005, 06:38 PM
TC/914   I'll tell you what I think if you PM me as to ...   Jan 21 2005, 07:07 PM
736conver   I had a 2.0 914 engine in a type 1 chassis, fiberg...   Jan 21 2005, 07:20 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 21 2005, 08:13 PM
736conver     Jan 21 2005, 08:24 PM
Mueller
  Jan 21 2005, 08:30 PM
SpecialK   <...   Jan 21 2005, 08:36 PM
jwalters   ht...   Jan 21 2005, 09:07 PM
jwalters   ...   Jan 21 2005, 10:27 PM
bondo   Wow, I'm intrigued. How much HP and torque are...   Jan 21 2005, 11:13 PM
Aaron Cox     Jan 21 2005, 11:16 PM
jwalters     Jan 21 2005, 11:53 PM
andys   What are each of the "net" ratios (1 thru 4 x fina...   Jan 21 2005, 11:58 PM
jwalters     Jan 22 2005, 12:13 AM
andys   ...   Jan 22 2005, 12:29 AM
GWN7   I wonder how it would work with a V8?   Jan 22 2005, 01:43 AM
jwalters     Jan 22 2005, 02:10 AM
jwalters     Jan 22 2005, 02:40 AM
SpecialK   I hear ya talkin', but all I see is your avata...   Jan 22 2005, 03:58 AM
redshift   You are never going to be happy with a gear that l...   Jan 22 2005, 05:59 AM
carambola   i don't know about ratio's and stuff like ...   Jan 22 2005, 06:48 AM
scotty b   Bus tranny will bolt right up to a type 4 engine, ...   Jan 22 2005, 08:26 AM
TC/914   I just had RANCHO build a type I swing axle trans ...   Jan 22 2005, 08:57 AM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 22 2005, 09:01 AM
scotty b   TC what did you have to do to mount the vw trans i...   Jan 22 2005, 09:04 AM
jwalters     Jan 22 2005, 09:08 AM
carambola   i appologize must have been thinking of something ...   Jan 22 2005, 10:01 AM
TC/914   Hey Guys, I just got the shipping confirmation fr...   Jan 22 2005, 01:13 PM
jwalters   http://www.914world.com/bbs2/ht...   Jan 22 2005, 02:33 PM
Tom Perso   I had a Rancho IRS trans in my Bug with a 2270cc T...   Jan 22 2005, 06:43 PM
andys   ...   Jan 22 2005, 10:47 PM
reverie   Tom Perso, that was excellent info... thank you...   Jan 22 2005, 11:19 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 23 2005, 07:55 AM
Cap'n Krusty     Jan 23 2005, 10:35 AM
jwalters   Yea well the buggie guys are more interested in tr...   Jan 23 2005, 11:02 AM
andys   ...   Jan 24 2005, 12:58 PM
Mueller   Andy, thanks for the link...that is pretty slick ...   Jan 24 2005, 01:17 PM
Cap'n Krusty   ...   Jan 24 2005, 02:52 PM
Tom Perso   The diameter of all the input shafts (that we are ...   Jan 24 2005, 03:25 PM
Cap'n Krusty
- Lo-Fi Version Time is now: 26th April 2025 - 02:37 AM
