Autox tire choices |
jmargush |
Jun 20 2023, 08:50 AM
Member Group: Members Posts: 465 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am in need of new autox tires and the offerings have changed a bit since I last bought a set.
I am curious as to what people are running?, what do you like? is there a good trade off cost/performance? I will be mounting them on 15x6 cookie cutters |
brilliantrot |
Jul 1 2023, 06:50 AM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
Aaron’s car is no feather weight. Around 2200lb with driver.
A tire engineer once told me 1psi per 100lbs is a good starting point and we have found that to be true. Aaron’s car is still a little camber limited so we usually run right around 23-24psi hot to try and keep the shoulder alive. Here’s what 24psi in a 1.3g corner looks like. Pretty good stretch for a 205 on a 7in wheel. |
jmargush |
Jul 2 2023, 04:14 PM
Aaron’s car is no feather weight. Around 2200lb with driver. A tire engineer once told me 1psi per 100lbs is a good starting point and we have found that to be true. Aaron’s car is still a little camber limited so we usually run right around 23-24psi hot to try and keep the shoulder alive. Here’s what 24psi in a 1.3g corner looks like. Pretty good stretch for a 205 on a 7in wheel. So you managed to get 7" cookies to fit? Did you have do so some fender pulling? |
Lo-Fi Version | Time is now: 22nd November 2024 - 07:35 AM |
