> Rear chassis flex. What do you think?, Discovery prepping for Road America next week
vintage914racer
post Jul 7 2023, 08:34 PM
Paranoia has set in as I'm nut and bolting the 914 before Road America next week. I'm hoping I can some second opinions.
A little background. My 914 has been a track car for nearly the entirely of it's life. She's been used and abused, but generally has been a reliable steed. Over the years chassis reinforcement and modifications have been made. Notably, the RR (pass) rear suspension console was replaced after the original tore (which is seemingly pretty normal).
What I'm noticing. After getting my car up on stands and prepping/inspecting for the next event I noticed a small amount of tire wear on my inner driver's left fender. I initially attributed it to bumping up to wider tires last Fall (225 Hoosiers vs. 205 Kumhos), but started investigating further to make sure there wasn't something else upstream.
When I have the car on jack stands and put pressure on the LR wheel, there's what I consider quite a bit of flex at the outer A-arm mount and forward into the rear long. You can see it in the attached video. As a point of comparison, when I do the same on the RR/passenger rear wheel there is some flex, but not as much. It should be noted that I had the inner suspension console replaced on the passenger side a few years ago after the old one tore, so in theory it should be stronger.
The LR doesn't show any signs of tearing. It's also reinforced with stress bars on the outside and inside.
Left Rear Flex Video (the side I'm worried about): https://youtu.be/NZDbDg22dFI
https://www.youtube.com/watch?v=NZDbDg22dFI
Right Rear Flex Video (the "control" if you will): https://youtu.be/bQMBecKZ6Yc
https://www.youtube.com/watch?v=bQMBecKZ6Yc
My questions are as follows:
1) How much flex is normal? Is this outside what is normal?
2) My flex test doesn't necessarily translate to how torsion is applied to the chassis when the car is on the ground, so am I worrying about something that isn't relevant? Wouldn't the applicable stress while driving get suppressed in part by the rear shock?
3) Would you be concerned about running the car?
Mid-term I'm going to get the LR console replaced for peace of mind, get the reinforcements cleaned up and tidy. The question is, should I forego my race and get it repaired before running.
rick 918-S
post Jul 10 2023, 04:20 AM
Hey nice rack! -Celette
It was a nice day. When I arrived the suspension was off so it wasn't real easy to see what happened. Ben made up a quick lever out of some square tubing and bolted it to the three point mount. With a little pressure it was clear what was moving. The upper spot welds had completely unzipped from the bottom to the top of the inner rail.
I went over and checked the right side and the same thing had occurred. The right side was not as obvious as the suspension console had been replaced and it was tied into the roll bar.
The easies fix was to use Drill Screws to pull the flange back in place. As I removed one screw at a time I used a 1/4 drill to flare the hole and expose the inner flange. I just plug welded both sides. Should be good to go.
If you race or AX alot you may want to check to see if this is happening. Just stick a screw driver or pry bar between the panel and the flang and see if moves. My 6 is stitch welded from the engine bay side along the top edge of the inner flange as it used to be a race/AX car. Even with this method and a poor welding job I can see some of the welds did not hold like a spot weld thru the flange would.
It was nice to see Ben again. It has been a few years. Time flies..
infraredcalvin
post Jul 12 2023, 09:28 PM
Distracted Member
QUOTE(rick 918-S @ Jul 10 2023, 03:20 AM) *
Seems like this fix might be good preemptive measure when installing gt reinforcement kit in wheel wells if planning on heavy tracking or autox…
vintage914racer   Rear chassis flex. What do you think?   Jul 7 2023, 08:34 PM
gms   It is very hard to tell what is loose from the vid...   Jul 8 2023, 07:10 AM
vintage914racer   It is very hard to tell what is loose from the vi...   Jul 8 2023, 07:37 AM
brant   thats scary looking.. really unpredictable rear s...   Jul 8 2023, 07:58 AM
vintage914racer   thats scary looking.. really unpredictable rear ...   Jul 8 2023, 08:23 AM
rick 918-S   Definately metal fatigue. Drop the suspension. I a...   Jul 8 2023, 10:18 AM
SirAndy   Definately metal fatigue. :agree: That's ...   Jul 8 2023, 10:28 AM
Bullethead   :agree: That's a scary amount of movement... f...   Jul 8 2023, 11:29 AM
vintage914racer   Pulling the trailing arm tomorrow and investigatin...   Jul 8 2023, 01:06 PM
rick 918-S   I'm heading down to see if I can assist Ben. T...   Jul 8 2023, 07:17 PM
Krieger   That looks scary to drive! I can't imagin...   Jul 9 2023, 08:39 AM
vintage914racer   A huge thank you to Rick (rick918-s) for coming do...   Jul 9 2023, 06:38 PM
SirAndy   Following an afternoon of drilling, temporarily fa...   Jul 9 2023, 09:58 PM
vintage914racer   RE: Rear chassis flex. What do you think?   Jul 9 2023, 06:38 PM
Bullethead   :trophy: Great job! :trophy:   Jul 9 2023, 06:54 PM
SirAndy   :trophy: Great job! :trophy: :agree: :beer...   Jul 9 2023, 09:55 PM
infraredcalvin   :cheer: :cheer: :cheer: That is so awesome...   Jul 9 2023, 09:55 PM
rick 918-S   It was a nice day. When I arrived the suspension w...   Jul 10 2023, 04:20 AM
infraredcalvin   It was a nice day. When I arrived the suspension ...   Jul 12 2023, 09:28 PM
gms   Great work Ben & Rick! See you at Road Ame...   Jul 10 2023, 09:14 AM
vintage914racer   Great work Ben & Rick! See you at Road Am...   Jul 10 2023, 02:17 PM
slivel   Is this a crack?   Jul 10 2023, 01:04 PM
vintage914racer   Is this a crack? That's not a crack. That...   Jul 11 2023, 08:11 PM
gms   Is this a crack? No that is the lower edge of ...   Jul 12 2023, 01:40 PM
sixaddict   This thread helped a lot as have similar issues â€...   Jul 10 2023, 07:14 PM
vintage914racer   Following Rick's miraculous short notice repai...   Jul 11 2023, 08:16 PM
vintage914racer   Quick update after attending the WeatherTech Inter...   Jul 19 2023, 10:31 AM
SirAndy   Quick update after attending the WeatherTech Inte...   Jul 21 2023, 08:41 PM
Charles Freeborn   Quick update after attending the WeatherTech Inte...   Jul 22 2023, 09:36 AM
brant   That is awesome Brant   Jul 20 2023, 08:28 AM
blabla914   glad to hear you got it fixed and were able to get...   Sep 3 2023, 07:06 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:55 AM
