Replacing fuel lines |
aeginc77 |
Jul 21 2023, 09:59 AM
Newbie Group: Members Posts: 19 Joined: 29-April 15 From: United States Member No.: 18,682 Region Association: None |
I can't be the only owner of a 914 that has had deteriorating rubber fuel lines but I can't seem to find the right posts covering this. Basically the fabric covered rubber fuel lines seem to deteriorate and split probably as a result of the ethanol in the fuel. Does anyone know if there are any replacements that hold up with the ethanol fuel. I ordered a new 7mm line from Pelican Parts and it seems to be the same German fabric covered rubber that was originally installed.
BillJ |
Jul 21 2023, 10:43 AM
Senior Member Group: Members Posts: 1,121 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
For correct you need to use the fabric covered. However i purchased new lines specifically rated for FI from flaps for piece of mind. This, coupled with stainless steel, was perfect and safe.
Lo-Fi Version | Time is now: 26th June 2024 - 02:18 AM |
