aeginc77 |
Newbie ![]() Group: Members Posts: 19 Joined: 29-April 15 From: United States Member No.: 18,682 Region Association: None ![]() |
I can't be the only owner of a 914 that has had deteriorating rubber fuel lines but I can't seem to find the right posts covering this. Basically the fabric covered rubber fuel lines seem to deteriorate and split probably as a result of the ethanol in the fuel. Does anyone know if there are any replacements that hold up with the ethanol fuel. I ordered a new 7mm line from Pelican Parts and it seems to be the same German fabric covered rubber that was originally installed.
jhynesrockmtn |
Member ![]() ![]() Group: Members Posts: 420 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest ![]() ![]() |
AA sells an engine compartment fuel line kit. I've replaced them on a couple of cars along with the tunnel lines with stainless from Tangerine Racing. You'll need a bit of extra hose to do the gas tank to the stainless lines and lines from the rear firewall to the stainless lines Chris supplies that go from underneath the engine to the engine compartment.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
AA sells an engine compartment fuel line kit. I've replaced them on a couple of cars along with the tunnel lines with stainless from Tangerine Racing. You'll need a bit of extra hose to do the gas tank to the stainless lines and lines from the rear firewall to the stainless lines Chris supplies that go from underneath the engine to the engine compartment. I’m pretty sure Chris still sells all 4 ss lines. Engine and tunnel. You can call him and ask but that’s where I’ve always bought mine. |
jhynesrockmtn |
AA sells an engine compartment fuel line kit. I've replaced them on a couple of cars along with the tunnel lines with stainless from Tangerine Racing. You'll need a bit of extra hose to do the gas tank to the stainless lines and lines from the rear firewall to the stainless lines Chris supplies that go from underneath the engine to the engine compartment. I’m pretty sure Chris still sells all 4 ss lines. Engine and tunnel. You can call him and ask but that’s where I’ve always bought mine. I just did new lines in my Bumblebee with Chris's lines. The kit came with 5. There is a small reducer that connects to the larger supply line coming from the fuel tank down to the smaller hose size. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:05 AM |
