> Bus 4 spd trans, Anybody done this
jwalters
post Jan 21 2005, 06:38 PM
Sooo Close.......
Region Association: Europe
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Thought of an interesting topic---has anybody put a beefed up bus or t1 trans in the teener----
I loved the gear spacing on my old superbug--and first gear for my car,,well,,,sucks ass--and second is too tall for a good start off--
Would rather spend 650 bucks on a pro-streeter WITH a rhino case and super diff than thousands upgrading my 901--
Sand rail mid engine cable shifter should be able to be adapted rather easily and the trans install is a non-event...
What you think???? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
jwalters
post Jan 23 2005, 11:02 AM
Sooo Close.......
Yea well the buggie guys are more interested in trannies other than the 901-----
And to take off my side plates and swap the diff is a non-event--no pinion to pull--and just keep the same shims on the respective side--a quick check with prussian blue would show it will be more than ok for running---
but you do have to change the input shaft bearing--the T1 tranny snout is a larger diameter than the 901??
I know a 200 mm disc will run fine in the 215 flywheel and plate...and the linkage is still a pull, like the 901, and a quick check will show the pulley and mount will bolt up to the side case like the 901.
Mounting the trans to the 914 chassis is super easy--a pair of mild steel elephant ears bolted to the shift cap perimeter with extended studs , and with a section bent to the proper angle to mate to the rubber mounts is a brake press and plate bender away...too easy to do---and my cv output shafts bolt right up to the T1, so no changing components there-
I just want to do away with a red herring---I have 3 901's that all need work--and again, for the price of a set of synchros----------------------------
BTW- has anybody ever noticed that the 901 says VW on it???
jwalters   Bus 4 spd trans   Jan 21 2005, 06:38 PM
TC/914   I'll tell you what I think if you PM me as to ...   Jan 21 2005, 07:07 PM
736conver   I had a 2.0 914 engine in a type 1 chassis, fiberg...   Jan 21 2005, 07:20 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 21 2005, 08:13 PM
736conver     Jan 21 2005, 08:24 PM
Mueller
  Jan 21 2005, 08:30 PM
SpecialK   <...   Jan 21 2005, 08:36 PM
jwalters   ht...   Jan 21 2005, 09:07 PM
jwalters   ...   Jan 21 2005, 10:27 PM
bondo   Wow, I'm intrigued. How much HP and torque are...   Jan 21 2005, 11:13 PM
Aaron Cox     Jan 21 2005, 11:16 PM
jwalters     Jan 21 2005, 11:53 PM
andys   What are each of the "net" ratios (1 thru 4 x fina...   Jan 21 2005, 11:58 PM
jwalters     Jan 22 2005, 12:13 AM
andys   ...   Jan 22 2005, 12:29 AM
GWN7   I wonder how it would work with a V8?   Jan 22 2005, 01:43 AM
jwalters     Jan 22 2005, 02:10 AM
jwalters     Jan 22 2005, 02:40 AM
SpecialK   I hear ya talkin', but all I see is your avata...   Jan 22 2005, 03:58 AM
redshift   You are never going to be happy with a gear that l...   Jan 22 2005, 05:59 AM
carambola   i don't know about ratio's and stuff like ...   Jan 22 2005, 06:48 AM
scotty b   Bus tranny will bolt right up to a type 4 engine, ...   Jan 22 2005, 08:26 AM
TC/914   I just had RANCHO build a type I swing axle trans ...   Jan 22 2005, 08:57 AM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 22 2005, 09:01 AM
scotty b   TC what did you have to do to mount the vw trans i...   Jan 22 2005, 09:04 AM
jwalters     Jan 22 2005, 09:08 AM
carambola   i appologize must have been thinking of something ...   Jan 22 2005, 10:01 AM
TC/914   Hey Guys, I just got the shipping confirmation fr...   Jan 22 2005, 01:13 PM
jwalters   http://www.914world.com/bbs2/ht...   Jan 22 2005, 02:33 PM
Tom Perso   I had a Rancho IRS trans in my Bug with a 2270cc T...   Jan 22 2005, 06:43 PM
andys   ...   Jan 22 2005, 10:47 PM
reverie   Tom Perso, that was excellent info... thank you...   Jan 22 2005, 11:19 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 23 2005, 07:55 AM
Cap'n Krusty     Jan 23 2005, 10:35 AM
jwalters   Yea well the buggie guys are more interested in tr...   Jan 23 2005, 11:02 AM
andys   ...   Jan 24 2005, 12:58 PM
Mueller   Andy, thanks for the link...that is pretty slick ...   Jan 24 2005, 01:17 PM
Cap'n Krusty   ...   Jan 24 2005, 02:52 PM
Tom Perso   The diameter of all the input shafts (that we are ...   Jan 24 2005, 03:25 PM
Cap'n Krusty
- Lo-Fi Version Time is now: 26th April 2025 - 02:50 AM
