aeginc77 |
Newbie ![]() Group: Members Posts: 19 Joined: 29-April 15 From: United States Member No.: 18,682 Region Association: None ![]() |
I can't be the only owner of a 914 that has had deteriorating rubber fuel lines but I can't seem to find the right posts covering this. Basically the fabric covered rubber fuel lines seem to deteriorate and split probably as a result of the ethanol in the fuel. Does anyone know if there are any replacements that hold up with the ethanol fuel. I ordered a new 7mm line from Pelican Parts and it seems to be the same German fabric covered rubber that was originally installed.
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 860 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
OK....I just went through this....when I would head out to the car and see a puddle of gas under it it kinda' ruined my mood to even start the car let alone go on a drive. I used the fabric covered lines to be correct and "european" but the ethanol in Los Angeles chews them right up. The fix is using R30 9 fuel line from Gates or Continental.....Cadna 50087 is the Continental brand at advanced auto parts....what a difference!!!! Good luck....doing all of the work under the car left me with a stiff neck...took two months...no leaks now though....Euro trash !!!
gg |
aeginc77 |
OK....I just went through this....when I would head out to the car and see a puddle of gas under it it kinda' ruined my mood to even start the car let alone go on a drive. I used the fabric covered lines to be correct and "european" but the ethanol in Los Angeles chews them right up. The fix is using R30 9 fuel line from Gates or Continental.....Cadna 50087 is the Continental brand at advanced auto parts....what a difference!!!! Good luck....doing all of the work under the car left me with a stiff neck...took two months...no leaks now though....Euro trash !!! gg I think I am facing replacing all the lines. Did you have to remove the fuel tank to get to the hoses that go into the tank. My 914 is a 1975 so the fuel pump is in the front trunk but I think I still need to remove the tank to access the hoses. There is a small access plate under the car but it doen't look big enough to easily change hoses. Your thoughts? Alan |
Lo-Fi Version | Time is now: 26th June 2024 - 02:18 AM |
