Broken bolt flange on heat exchanger, Can it be welded back on? |
DC_neun_vierzehn |
Jun 2 2023, 03:58 PM
Member Group: Members Posts: 418 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
During reinstall of a freshly rebuilt motor we discovered one of bolt flanges (also called dog ears?) on the driver's side heat exchange was cracked at the weld. We decided to proceed with installing knowing that I would need to get it addressed soon. Well ... that flange completely broke off when mounting it.
I have no experience welding nor do I own the welding equipment - my question is can that be welded back on good as new ... or do I have to replace the exchanger? The heat exchanger is in great shape with no signs of rust or leaks anywhere. So it would be great if I can have it welded vs. needing to replace. Thanks in advance. |
nditiz1 |
Jul 26 2023, 02:44 PM
Senior Member Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Can you just grind down the ear. You will have less clamping area, but these don't need 35 ft/lbs to install. The reason they were broken in the first place was due to overtightening.
DC_neun_vierzehn |
Jul 26 2023, 03:11 PM
Can you just grind down the ear. You will have less clamping area, but these don't need 35 ft/lbs to install. The reason they were broken in the first place was due to overtightening. Damn. That’s a great idea. I would consider trying that, but I’m also noticing that now one of the two pipes on the HE is not a perfect oval (looks bent) so it won’t mate with the oval head port and copper washer … that is also going to cause problems. That must have happened on one of their re-weld attempts. Man … I’m cursed on this attempt to repair rather than replace the HE. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:51 PM |
