17mm vs 19mm Brake Master Cylinder, again! |
87m491 |
Jul 24 2023, 05:32 AM
Member Group: Members Posts: 295 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
With the prospect of incoming rotten tomatoes forefront, I wade in here looking for a little BTDT.
Background, just got the 74, 2.0 back on the road after a 7 year hiatus. Over the years,, I did fuel system, brake system (19mm master(ATE) /calipers (PMB rebuilt fronts, stock rears) /rotors/hoses) engine mechanicals and cosmetics. I haven't driven the car during that time and I only had about 150 miles on it before it came off the road and memory ain't what it used to be. I did the 19mm MC many years back because it was way less expensive than the 17 and the forum feedback seemed fine. I also have a mid 80's Carrera (with turbo brakes) against which many folks relate the 19mm MC pedal feel. I like a firm pedal and the 911 is pretty easily modulated, heavy but responsive. Fast forward to this past week and some short shakedown runs. The 914 pedal is "right there" and noticeably firmer than the 911. But while being firmer, the braking is far from commensurate with pedal input. Yes, the 911 pedal is firm, but with the right effort, the car will slow/stop NOW. Been on the track with it no problem. On the 'teener, I feel like I am about to bend/break the pedal and the car seems to barely slow. No way I can lock up these brakes at any road speed, nor do I feel I could lose momentum in a hurried stop situation, even at in town speeds. I'm wondering if I have missed something or is this type of pedal feel/action is "typical" of the swap? Shamefully, I honestly can't recall if I did pads, but the rotors are spotless and look like they're getting good pad contact but would love any pad advice as well. |
914sgofast2 |
Jul 28 2023, 06:15 PM
Senior Member Group: Members Posts: 645 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
What kind of brake pads are you running? If they are racing brake pads (i.e., Porterfield brand), they won't have any stopping power until you have heated them up a lot; that is why "racing" brake pads are a big mistake on street cars. If they are normal street brake pads, then I would suspect that the rubber brake hoses have perished and collapsed inside and are preventing the brake fluid from exerting full pressure on the calipers. Second thing to question is the life left in the 19mm master brake cylinder's seals. If they have just been sitting for 7 years, they have probably gone hard/bad, as will the seals in the calipers. Brake systems are like our bodies; if you sit around for 7 years without any exercise, don't expect to be able to go out and run (or walk) a 10K marathon. Everything needs regular exercise!
Lo-Fi Version | Time is now: 21st September 2024 - 07:18 PM |
