> Coil on plug?
AndrewBlyholder
post Jul 11 2023, 11:45 PM
The ignition on my 914 race car motor is currently a Mallory CDI box and coil with the spark running through the distributor. I'm thinking to simplify things by going to individual coil-on-plug packs on each spark plug. The fuel injection ECU can then control the ignition directly without any other intervening equipment. This is a Type IV motor with the stock cooling tin. Any recommendations out there on what brand of coil packs to use? Any suggestions on easy ways to mount them to the engine tin?
Might also add a cam sync sensor in the distributor hole rather than do wasted spark. Any advice or experience with those parts would be appreciated too.
Thank,
Andrew B.
jd74914
post Jul 30 2023, 09:11 PM
Its alive
Another vote for LS2 coils. They are awesome. Performance is fantastic and they are quite easy to install since you only need to worry about making custom plug wires.
I've even used them in place of the stock ignition boxes on a gas turbine ignitor. (IMG:style_emoticons/default/laugh.gif)
- Lo-Fi Version Time is now: 3rd April 2025 - 01:33 AM
