VolksSled |
Newbie ![]() Group: Members Posts: 28 Joined: 3-May 23 From: California Member No.: 27,331 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/beer3.gif)
Can someone recommend where to buy replacement shock s and struts I’m looking for the most comfortable ride not knife edge handling Since I’ve gotten back into 914 s I’m seeing coil over rear setups being sold now (IMG:style_emoticons/default/type.gif) Should I be leaning towards that or just replacing the stock stuff ? (IMG:style_emoticons/default/stirthepot.gif) And what kinda budget should i plan for ?$ ( I already know I don’t have elephant racing type money $ ) * Attached image(s) ![]() |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,999 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
About to purchase replacement shocks and struts. Finally replacing the KYBs the PO installed. I don’t see anything but Konis available for struts. Does Bilstein make struts?
I still have to stock springs on the car, but I have a box with nearly new 100 lb weltmeister springs that I plan on using. They measure ~ 10” unsprung. Will the Koni’s minimal height adjustment (compared to the Bilsteins) allow me to lower the rear enough? Is mixing Konis in the front with Bils in the back a bad idea? Leaning toward Konis, but worried about the limited height adjustment for the rears. |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 882 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
About to purchase replacement shocks and struts. Finally replacing the KYBs the PO installed. I don’t see anything but Konis available for struts. Does Bilstein make struts? I still have to stock springs on the car, but I have a box with nearly new 100 lb weltmeister springs that I plan on using. They measure ~ 10” unsprung. Will the Koni’s minimal height adjustment (compared to the Bilsteins) allow me to lower the rear enough? Is mixing Konis in the front with Bils in the back a bad idea? Leaning toward Konis, but worried about the limited height adjustment for the rears. Personally, I think it’s a bad idea to mix brands of shocks/struts. Valving, rebound ride consistency etc etc can become a problem. |
Lo-Fi Version | Time is now: 27th June 2024 - 03:04 PM |
