Sbgunderson |
Newbie ![]() Group: Members Posts: 3 Joined: 31-July 20 From: Maryland Member No.: 24,557 Region Association: MidAtlantic Region ![]() |
Happy Memorial Day, I hope everyone is doing well.
I am working on a tube chassis design. And I was wondering how your semi-trailing arms sit at ride height. Also if someone has an idea of an acceptable range and how that might affect alignment. It would probably be easiest to measure the angle on the top of the arm rather than the angle through the center of the wheel-bearing…. When you find a few minutes I would love to hear your semi-trailing arm angle at ride height! Thank you in advance Spencer |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 941 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
Not sure if there is an ideal angle per se. If you are looking to optimize and are open to moving things around, it would be ideal to set the roll centers where you want them (and for the front too). 914 rear roll centers are high due to the trailing arm design. There are some limitations if you are planning to use the standard trailing arms. Many people raise the pickup points so the arms aren't at such an extreme angle when the car is lowered. I think I raised mine 3/4" - that was what I could conveniently get.
Trackd |
Newbie ![]() Group: Members Posts: 28 Joined: 23-January 20 From: Buffalo, NY Member No.: 23,854 Region Association: None ![]() |
Not sure if there is an ideal angle per se. If you are looking to optimize and are open to moving things around, it would be ideal to set the roll centers where you want them (and for the front too). 914 rear roll centers are high due to the trailing arm design. There are some limitations if you are planning to use the standard trailing arms. Many people raise the pickup points so the arms aren't at such an extreme angle when the car is lowered. I think I raised mine 3/4" - that was what I could conveniently get. How did you raise your rear pickup points? Any pictures? |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:55 AM |
