Noise insulation, Engineer types opinions needed |
nivekdodge |
Aug 10 2023, 07:12 PM
Member Group: Members Posts: 281 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
Just a thought
There's another thread today discussing using perlon for the back pad and if it was quieter or not. Something I've notice is Some GM hood have their inner surface looking like a golf ball. There are 3" round divots and when asked about it I was told it reflects the sound back to the motor and that kills the sound.Anyone know if there is truth to this? This would of course be in the engine compartment. Kevin |
r_towle |
Aug 13 2023, 09:37 AM
Custom Member Group: Members Posts: 24,661 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You can attack the firewall problem but in the end the rear window will become the loudest transference of noise.
I think the OEM engine bay rubber pad glued to insulation gave pretty decent results. I might suggest adding dynamite to the interior of the firewall in addition to the oem engine bay pad, then call it quits. Rich |
Bucci |
Aug 13 2023, 10:17 AM
Bucci Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California |
You can attack the firewall problem but in the end the rear window will become the loudest transference of noise. I think the OEM engine bay rubber pad glued to insulation gave pretty decent results. I might suggest adding dynamite to the interior of the firewall in addition to the oem engine bay pad, then call it quits. Rich Good morning Rich, I did a dual glaze rear window on my 914 almost 30 years ago. Look at the picture below, the identification on the glass is mirrored or doubled. In fact, right after I put in the 3.2 L motor I ran without a back window for almost a year. Rain does not get into the car when you’re going forward. Lol |
Superhawk996 |
Aug 13 2023, 10:29 AM
914 Guru Group: Members Posts: 6,598 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
You can attack the firewall problem but in the end the rear window will become the loudest transference of noise. I think the OEM engine bay rubber pad glued to insulation gave pretty decent results. I might suggest adding dynamite to the interior of the firewall in addition to the oem engine bay pad, then call it quits. Rich Good morning Rich, I did a dual glaze rear window on my 914 almost 30 years ago. Look at the picture below, the identification on the glass is mirrored or doubled. In fact, right after I put in the 3.2 L motor I ran without a back window for almost a year. Rain does not get into the car when you’re going forward. Lol Creative - I didn’t realize you can fit two layers of glass in there. How did you secure the second pane of glass? Modern luxury cars often use thicker and sometimes laminated glass on side and rear windows as a way to reduce NVH. The lamination layer acts like constrained layer damping impeding sound transfer from one pane of glass to the other. |
vitamin914 |
Aug 13 2023, 11:06 AM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
You can attack the firewall problem but in the end the rear window will become the loudest transference of noise. I think the OEM engine bay rubber pad glued to insulation gave pretty decent results. I might suggest adding dynamite to the interior of the firewall in addition to the oem engine bay pad, then call it quits. Rich Good morning Rich, I did a dual glaze rear window on my 914 almost 30 years ago. Look at the picture below, the identification on the glass is mirrored or doubled. In fact, right after I put in the 3.2 L motor I ran without a back window for almost a year. Rain does not get into the car when you’re going forward. Lol Creative - I didn’t realize you can fit two layers of glass in there. How did you secure the second pane of glass? Modern luxury cars often use thicker and sometimes laminated glass on side and rear windows as a way to reduce NVH. The lamination layer acts like constrained layer damping impeding sound transfer from one pane of glass to the other. I like the double glazing. Nicely done. Laminated glass is a good idea too... Lots of high end Mercedes use this trick. I have a spare 914 b/w that I will need to look at. I think it is basically a flat piece of tempered glass with little to no cross car curvature. You can buy panes of laminated flat glass - doubtful it is DOT rated, but... digitize a sample b/w and drop a laminated blank into a FlowJet water cutting machine - and an instant laminated back window glass for the 914. Of course your would need to mask-off the cut area to prevent etch from the garnet abrasive. I had water jet cutting done on a small 12"x12" piece of laminated glass that worked out well for an industrial porthole. I am going to have to look into this. |
Lo-Fi Version | Time is now: 27th December 2024 - 12:07 AM |
