Head rebuild advice for 103mm cut heads, Reweld or buy new, who's running 103? |
nditiz1 |
Aug 22 2023, 07:36 PM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
EDIT: Head is toast. Looking to source replacement ones. So I'm tearing into the FAT perfomance 2.6 engine. I was going to try to run it, but before that went to perform a leak down and saw a gaping hole in #4 next to the plug. I just removed the head and it looks good other than previous welding I assume FAT did when the built the heads. There is little material amount between the camber and the edge of the head due to the cut of 103 P&C. Is this just the evil of hipo engines or are better options out there? Should I have these rewelded OR buy new 103 cut heads? Who out there is running big power? Also I know Raby spoke highly about FAT engines, but damn did they love RTV. |
Mikey914 |
Aug 22 2023, 10:42 PM
The rubber man Group: Members Posts: 12,729 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'd start with new metal. Only way to know for sure you will not have issues in the future in this area. Had to have been real loud.
Lo-Fi Version | Time is now: 31st October 2024 - 07:23 PM |
