Which Springs would you intall?, The never ending BB take apart/redo continues |
jhynesrockmtn |
Aug 23 2023, 06:41 PM
Member Group: Members Posts: 425 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I am refreshing the rear suspension on my BB. Yet another project I hadn't really planned on but here we are.
I now have everything I need to reinstall the rear trailing arms and shocks. The arms got painted new bushings and bearings (thanks @iankarr and 914rubber). New Koni sports from Paragon (thanks Jason), PMB rebuilt brake calipers (thanks Eric). I found some new/old Weltmeister SP100's in a box of parts a PO had bought for another project car I have. See the photos. The only mark on the springs that came off the BB are a redish paint on each coil. The car did sit lower than stock by my eye. See photo. I don't know much about the SP100 but they do look pretty :-) Would you go all the way and install the "new" springs. I realize 100lbs are stiffer than stock. I could always go back if I don't like the ride. The koni's aren't full coil overs but have a bit of ride height adjustment. The middle clip position matches the old Koni shocks I removed. The springs do sit 2 to 3 mm taller with no compression. |
Shivers |
Aug 24 2023, 08:38 AM
Senior Member Group: Members Posts: 2,781 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I have the 140 lbs on my car, the 100’s should be nice for play and still have some give.
Lo-Fi Version | Time is now: 25th November 2024 - 08:26 AM |
