Whats that click in my engine, No compression, Valve stuck open maybe. |
slapshot |
Aug 31 2023, 12:45 PM
Member Group: Members Posts: 58 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains |
Yesterday just before getting home I heard a click from the engine then again. It wasn't steady, just every little bit I would hear it. I could feel that I lost power and it even stalled once at a stop light. Since I was only a couple block from home I just keep going.
I found that cylinder 3 could only produce 20 lbs of compression. A leak down test was 22% with most air coming out of the intake. For reference the other cylinders were 100 to 105 compression and the leak down was 18% to 20% with air noticed just in the oil filler hole. I don't know how accurate my testing tools are since they are cheap ones I got from amazon and harbor freight. I took off of my valve cover for cylinders 3 and 4 and with cylinder 3 at TDC I have over 1/2 inch of play with both valves and the pushrods are of course way loose. I haven't removed the rockers to pull the pushrods out yet to see if they are bent. I will do that after I pulling the engine either tomorrow or this weekend. How screwed am I? Thoughts on best and worse case? Here's a video of my loose rocker Video of rockers |
rhodyguy |
Sep 1 2023, 08:30 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
End result, to me, is a complete rebuild and EVERY thing else that gets done while you’re in there. Starting with any case work. It gets expensive. Quickly.
Lo-Fi Version | Time is now: 28th June 2024 - 08:11 PM |
