slapshot |
Member ![]() ![]() Group: Members Posts: 58 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains ![]() ![]() |
Yesterday just before getting home I heard a click from the engine then again. It wasn't steady, just every little bit I would hear it. I could feel that I lost power and it even stalled once at a stop light. Since I was only a couple block from home I just keep going.
I found that cylinder 3 could only produce 20 lbs of compression. A leak down test was 22% with most air coming out of the intake. For reference the other cylinders were 100 to 105 compression and the leak down was 18% to 20% with air noticed just in the oil filler hole. I don't know how accurate my testing tools are since they are cheap ones I got from amazon and harbor freight. I took off of my valve cover for cylinders 3 and 4 and with cylinder 3 at TDC I have over 1/2 inch of play with both valves and the pushrods are of course way loose. I haven't removed the rockers to pull the pushrods out yet to see if they are bent. I will do that after I pulling the engine either tomorrow or this weekend. How screwed am I? Thoughts on best and worse case? Here's a video of my loose rocker Video of rockers |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,935 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Hoping that is the only issue and can be fix and able to drive the car again.
Probably over tighten that made it broke. |
Lo-Fi Version | Time is now: 28th June 2024 - 08:16 PM |
