jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Thought of an interesting topic---has anybody put a beefed up bus or t1 trans in the teener---- I loved the gear spacing on my old superbug--and first gear for my car,,well,,,sucks ass--and second is too tall for a good start off-- Would rather spend 650 bucks on a pro-streeter WITH a rhino case and super diff than thousands upgrading my 901-- Sand rail mid engine cable shifter should be able to be adapted rather easily and the trans install is a non-event... What you think???? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
If by "input shaft bearing" you mean the pilot bearing in the flywheel (or gland nut or crankshaft), they're the same part number. VW used the same input shaft "snout" diameter on RWD vehicles until the end of the Vanagons. Porsche used it until the 915 tranny came into play. As for "opening up" the center of a bus flywheel, you simply knock out the sheetmetal insert, and insert the bearing. No machine work involved. The 914/4 901 style trannies (actually called the "914" tranny), say VW on them, the REAL 901s, and the 911s, and the 914/6 trannies were made by Porsche, the 4s were made under license by VW. The Porsche made gears have matching numbers imprinted on them, the VW made gears don't. As for the strength of 901s, a properly setup 914 tranny will hold up to a SBC or 911 motor for years of normal use, and I see no reason why it wouldn't last you for years using a T4 motor. The Cap'n |
Lo-Fi Version | Time is now: 26th April 2025 - 02:40 AM |
