slapshot |
Member ![]() ![]() Group: Members Posts: 58 Joined: 11-June 23 From: Utah Member No.: 27,409 Region Association: Rocky Mountains ![]() ![]() |
Yesterday just before getting home I heard a click from the engine then again. It wasn't steady, just every little bit I would hear it. I could feel that I lost power and it even stalled once at a stop light. Since I was only a couple block from home I just keep going.
I found that cylinder 3 could only produce 20 lbs of compression. A leak down test was 22% with most air coming out of the intake. For reference the other cylinders were 100 to 105 compression and the leak down was 18% to 20% with air noticed just in the oil filler hole. I don't know how accurate my testing tools are since they are cheap ones I got from amazon and harbor freight. I took off of my valve cover for cylinders 3 and 4 and with cylinder 3 at TDC I have over 1/2 inch of play with both valves and the pushrods are of course way loose. I haven't removed the rockers to pull the pushrods out yet to see if they are bent. I will do that after I pulling the engine either tomorrow or this weekend. How screwed am I? Thoughts on best and worse case? Here's a video of my loose rocker Video of rockers |
slapshot |
I retapped the bolt, put the rocker back on and set the gaps. Going to put it back in the car tomorrow. As long as the bolt holds, everything should be back to normal. I'd say that the reason I had no compression on that cylinder was due to the valve not getting pushed open and since the leak down test was descent the valve seat should be okay.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I retapped the bolt, put the rocker back on and set the gaps. Going to put it back in the car tomorrow. As long as the bolt holds, everything should be back to normal. I'd say that the reason I had no compression on that cylinder was due to the valve not getting pushed open and since the leak down test was descent the valve seat should be okay. Did the retapped stud hold the correct torque ? ,looks like the other one has been helicoiled or some other insert. Good luck with this ,sorry to say but you are going to need it,cheers. |
Lo-Fi Version | Time is now: 28th June 2024 - 08:46 PM |
