> 914-6 LSD, Did any 914-6 come with limited slip differential
DennisV
post Nov 3 2022, 08:44 AM
Did any 914-6 come from the factory with limited slip differential?
Based on what I see in the factory parts catalog, there is no reference to 914-6 that includes LSD.
If the answer is "yes" some came with LSD, is there a way you can tell by looking without opening the case?
Dave_Darling
post Sep 6 2023, 05:50 PM
914 Idiot
I believe the stock limited-slip uses clutches. They can and eventually do wear out. I don't know if they would make the car behave exactly like an open-diff car when they do, but it might.
Limited-Slip Differential is a broad term that encompasses many different types of diff, from locking diffs to clutch-type ones to worm-gear types (e.g., Torsen) and more besides. Posi-Traction is one specific type, and as noted above was specific to GM cars.
--DD
ClayPerrine
post Sep 6 2023, 06:12 PM
QUOTE(Dave_Darling @ Sep 6 2023, 06:50 PM) *
--DD
Yes, when any clutch type limited slip diff wear out the clutches, the diff then starts working like an open diff.
And you have to disassemble the diff, and replace the clutches. It is not an easy job. It takes some patience to get the clutch pre-load correct.
I much prefer Torsen style diffs. No clutches to wear out.
rgalla9146
post Sep 7 2023, 07:20 AM
QUOTE(ClayPerrine @ Sep 6 2023, 08:12 PM) *
--DD
(IMG:style_emoticons/default/agree.gif) I'm with Clay on that.
I have a 914 4cyl. trans (stamped HB, with Shell lube tag and
LSD diff carrier) that spins both hubs in the same direction.
So very likely clutches kaput.
post Sep 7 2023, 08:50 AM
Resident German
QUOTE(rgalla9146 @ Sep 7 2023, 06:20 AM) *
Errhm, if both spin the same direction, your LSD is working.
On an open diff, the wheels will spin the opposite direction.
DennisV   914-6 LSD   Nov 3 2022, 08:44 AM
Gustl   yes - it was the option M220 you can see it on the...   Nov 3 2022, 08:48 AM
mepstein   :)   Nov 3 2022, 08:49 AM
mgphoto   Search for the user Gustl he asked the same questi...   Nov 3 2022, 09:19 AM
DennisV   Search for the user Gustl he asked the same quest...   Nov 3 2022, 02:30 PM
sixaddict   So I was under impression if you turn output flang...   Nov 3 2022, 11:11 AM
Gustl   here is an example for a 914-6 transmission with L...   Nov 3 2022, 11:52 AM
914werke   RE: 914-6 LSD   Nov 3 2022, 11:54 AM
mgphoto   Anybody remaking this tag? I would really like ...   Nov 3 2022, 01:50 PM
Cairo94507   @mgphoto I would shoot CarBone in Poland an email...   Nov 3 2022, 02:26 PM
schleups   I just purchased a 1974 2.0 liter - it has over 10...   Sep 5 2023, 02:25 PM
mepstein   I just purchased a 1974 2.0 liter - it has over 1...   Sep 5 2023, 02:28 PM
windforfun   Doesn't a LSD have to be disengaged at speeds ...   Sep 6 2023, 09:58 AM
slivel   Doesn't a LSD have to be disengaged at speeds...   Sep 6 2023, 11:52 AM
flipb   [quote name='windforfun' post='3100313' date='Sep...   Sep 6 2023, 12:08 PM
Cairo94507   What a hottie!   Sep 6 2023, 02:36 PM
Dave_Darling   I believe the stock limited-slip uses clutches. T...   Sep 6 2023, 05:50 PM
ClayPerrine   I believe the stock limited-slip uses clutches. ...   Sep 6 2023, 06:12 PM
rgalla9146   I believe the stock limited-slip uses clutches. ...   Sep 7 2023, 07:20 AM
SirAndy   I have a 914 4cyl. trans (stamped HB, with She...   Sep 7 2023, 08:50 AM
rgalla9146   I have a 914 4cyl. trans (stamped HB, with Sh...   Sep 7 2023, 11:19 PM
technicalninja   Yes, when any clutch type limited slip diff wear...   Sep 7 2023, 08:27 AM
ClayPerrine   The transmission I have on the 2.4L six has a Quai...   Sep 7 2023, 12:16 PM
gms   I found on in this 914-4   Sep 8 2023, 09:11 AM
rgalla9146   I found on in this 914-4 My LSD story is in t...   Sep 8 2023, 10:23 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 02:20 AM
