Start up, A couple of questions. |
hndyhrr |
Sep 8 2023, 08:13 PM
Senior Member Group: Members Posts: 584 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I will be starting up the Pumpkin (70 , 1.7) It's been about 3 years since she was started.
Should I change oil first then start or start and run and then change oil when warm? Should I drip a little Marvel mystery oil in cylinders before start up ( yes I know she will smoke like hell)? I had extra injectors done by Mr. Injector, should I start up, change oil and then change injectors. Keeping fingers crossed it goes with no hick ups. lol Thanks Renee |
Robarabian |
Sep 8 2023, 09:25 PM
914 A Roo Group: Members Posts: 631 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Renee,
If it has been sitting that long, there is likely moisture in that oil. I would change it first. Hopefully you have turned the motor by hand over the years but many dont. You should lubricate the cylinders a bit. Doesnt have to be Marvel, it can be motor oil, but A little wouldn't hurt anything. Don't drown it. A better option might be aerosol Fogging oil (search it online) as you may be able to coat more of the cylinder. You might pull the plugs, put some oil in there, crank it a bit to build some oil pressure, then put it together and try to start it. Make sure the fuel is fresh. and pull the fuel pump relay when you do that. Either it will go or it wont. If it lights, get it up to operating temperature so any moisture in the motor can start to burn off. I'd change that oil again after 100 miles or so. I am sure others have differing opinions, but this doesn't sound like a race car and you're probably just trying to see if it will get on the road again. The new injectors won't care if the motor was sitting or not. You probably have a better shot starting it with the new injectors in place. Replace all the seals so you are sure there are no fuel leaks. Good luck. I will be starting up the Pumpkin (70 , 1.7) It's been about 3 years since she was started. Should I change oil first then start or start and run and then change oil when warm? Should I drip a little Marvel mystery oil in cylinders before start up ( yes I know she will smoke like hell)? I had extra injectors done by Mr. Injector, should I start up, change oil and then change injectors. Keeping fingers crossed it goes with no hick ups. lol Thanks Renee |
Lo-Fi Version | Time is now: 31st October 2024 - 08:19 PM |
