> Found a really slick subwoofer, Looks like it was designed for us
gereed75
post Aug 15 2022, 08:26 PM
Had been contemplating a stereo upgrade. Had read all the threads. Wanted something that would require minimal disturbance from stock and be unobtrusive
Had already committed to a period correct Blau Frankfurt with the digital conversion. I knew that the Infinity Kappas were a good solution in the original speaker housings so went with those. In looking for a small powered sub I found the Pioneer TS WX010A. Chose it because it is about the smallest one out there and is a small 50 watt amp that requires no heavy wiring
Figured it’s small size would provide a variety of mounting options without have to cut up any interior stuff. What I did not know was how well it would fit. After taking out the foam filler block, I found that This thing fits in the recess in the passenger footwell like it was designed to be there. See pix below
I held it into place using the double face tape provided with the sub. This tape also nicely isolates the speaker so it does not rattle against the firewall/floor structure. Once the foam block is trimmed and put back into place the carpet covers it all and it essentially is undetectable.
The thing has great adjustability in gain and frequency. Both are turned way down and provides all the bass you could ever want in our small cabin. Paired with the Kappas it sounds great
Overall a very sanitary installation and a pleasing ( to me anyway) solution.
gereed75
post Sep 14 2023, 09:39 AM
I suspect that teeing the regular wire outputs to the speakers will work. Caveat -not an audio expert. Might want to combine both outputs so that you get the bass input from both channels of the stereo output.
Let us know how it works. I think you will really like the sub.
gereed75   Found a really slick subwoofer   Aug 15 2022, 08:26 PM
ssstikircr   Is it just me :ttiwwp:   Aug 15 2022, 08:31 PM
gereed75   Working on it! There you go. Can’t get sp...   Aug 15 2022, 08:42 PM
JmuRiz   I got one for mine and my brother’s cars, I plan...   Aug 15 2022, 08:49 PM
gereed75   Nathan, pull the foam block and you will be amaze...   Aug 15 2022, 08:57 PM
Montreal914   Had already committed to a period correct Blau Fr...   Aug 15 2022, 11:52 PM
gereed75   There are several people that convert vintage radi...   Aug 16 2022, 07:25 AM
Montreal914   Thank you, I will look at my car/foam. :)   Aug 16 2022, 08:11 AM
windforfun   Very nice elegant & simple solution indeed. A...   Aug 16 2022, 11:44 AM
Rick986   Had been contemplating a stereo upgrade. Had read...   Aug 16 2022, 12:23 PM
bbrock   Thanks. Looks great! But are you saying that ...   Aug 16 2022, 09:28 PM
Rick986   Thanks. Looks great! But are you saying that...   Aug 17 2022, 08:48 AM
Root_Werks   Wonder if the built in amp is the class D? I inst...   Aug 16 2022, 03:18 PM
gereed75   You can select phase right on the amp with a simpl...   Aug 16 2022, 05:05 PM
Rick986   You can select phase right on the amp with a simp...   Aug 16 2022, 08:16 PM
gereed75   Tonight I added blue tooth to the system using the...   Aug 16 2022, 09:29 PM
gereed75   No need for a dedicated direct heavy wire with the...   Aug 17 2022, 09:07 AM
DRPHIL914   No need for a dedicated direct heavy wire with th...   Aug 17 2022, 10:29 AM
gereed75   Crutchfield. In my pictures you are seeing the un...   Aug 17 2022, 11:06 AM
JmuRiz   Easy to tune the way you mounted...good work,   Aug 17 2022, 01:02 PM
steuspeed   Specifically designed for passenger footwell locat...   Aug 17 2022, 02:30 PM
DennisV   @ gereed75 What I did not know was how well it wo...   Aug 18 2022, 11:19 AM
DC_neun_vierzehn   Had been contemplating a stereo upgrade. Had read...   Sep 13 2023, 01:52 PM
gereed75   Yea. My digital amp installed into the Blaupunkt h...   Sep 13 2023, 06:18 PM
DC_neun_vierzehn   Yea. My digital amp installed into the Blaupunkt ...   Sep 14 2023, 07:45 AM
jim_hoyland   How about a schematic for us visual learners ? :)   Sep 13 2023, 06:18 PM
gereed75   Here you go. Link to Pioneer manual https://www.p...   Sep 13 2023, 06:28 PM
gereed75   I suspect that teeing the regular wire outputs to ...   Sep 14 2023, 09:39 AM
chmillman   Has anyone ever tried mounting the Pioneer TS-WX01...   Aug 17 2024, 09:32 AM
chmillman   Has anyone ever tried mounting the Pioneer TS-WX0...   Aug 17 2024, 09:33 AM
East coaster   I put mine inside my center console. That said, it...   Aug 17 2024, 03:07 PM
chmillman   Quoting myself... So, yes, it does fit in a sto...   Sep 3 2024, 10:53 AM
drdriddle   I choose the less hidden route…and I realize itâ...   Sep 3 2024, 11:34 AM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 02:38 PM
