Torsion Bar Removal Tips |
DennisV |
Sep 3 2023, 07:39 PM
Senior Member Group: Members Posts: 590 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Any tips on how to remove a stubborn front torsion bar? I soaked it in penetrating oil. Clamped onto the end with vice grips. Pounded it from the sides with a plastic mallet. That thing is in there. I got so frustrated, I dropped the entire front suspension to see if I could get a better attack off the car. Still stuck.
As far I as can tell, there is no way to access the other end to pound it out. Only wiggle and pull? |
DennisV |
Sep 15 2023, 06:24 PM
I may be buying new a-arms and torsion bars. Today I'm back with the car. I tried:
I'm guessing if it is rusted in that bad, they both may be damaged beyond reasonable use. Anyone else faced this much resistance? |
Superhawk996 |
Sep 16 2023, 12:46 AM
914 Guru Group: Members Posts: 6,713 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
DennisV |
Sep 16 2023, 07:00 PM
Lots of penatrant oil and propane torch. More of this. Better yet - MAPP gas or oxy-acetylene. Thanks for the encouragement. It finally freed up after drilling the cap off, liberal oxy-acetylene application and a lot of banging. (IMG:style_emoticons/default/smash.gif) Wow. That was a lot more effort than I expected. I really love the videos where people slide them out with two fingers! I was expecting the torsions bar to be ate up with rust. Surprisingly not. I'm still not clear why it was so froze up. |
Superhawk996 |
Sep 16 2023, 10:16 PM
I'm still not clear why it was so froze up. Lots of surface area at the spline interface. Doesn’t take much corrosion on the splines to do a wonderful job of gluing parts together. A tiny corrosion ridge at the edge of the splines can also act like a wedge / stopper preventing the splines from sliding. The heat is needed to expand the LCA Inner Diameter more than the torsion bar Outer Diameter - allowing the parts to separate and slide free. (IMG:style_emoticons/default/smilie_pokal.gif) on the perseverance. When you reassemble - light coat of grease goes on the entire bar length (to prevent corrosion) but you want to be quite liberal with it at the splines. |
Lo-Fi Version | Time is now: 5th February 2025 - 07:03 AM |
