How did my high beams kill my ignition? |
87m491 |
Sep 14 2023, 05:31 PM
Member Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
After doing some bottom side work on my car last weekend (on ramps), and some dash bulb replacements, I went back topside to drive off the ramps (12 hours later) and absolutely no signs of life when ignition key is turned. No generator light, no oil light nada and of course no cranking. No fuses were blown. While the ignition switch hadn't exhibited symptoms of failing I figured I'd swap it out with a spare I had.
I swapped in the spare today. A bit of PITA so I went down an electrical check list before fully buttoning it up. Key on, dash lights check (generator and oil pressure, still stock incandescent bulbs) . Cranked over and instant start, check. Installed the directional and wiper switch stalk so I can check the functioning turn signals, check. All the illumination LEDs I installed in the gauges this week, check. Running lights, check. Headlights up and check. High beams to check high beam LED, saw the high beam indicator light, heard a relay, click, momentary check, then the dash went dark! Again, no fuses blown. Now I am back to the symptoms that led me to think it was the ignition switch. No lights at all on the dash with key on and of course no cranking. Hazards work, 1st position headlight switch items, gauge illumination works, 2nd position headlights do not and fogs do not. Data point, all of these items worked before the day before my first "dead electrical' experience last weekend. All wiring that I know of is stock. Looks like 'll be getting friendly with my multimeter once the coming storm passes through the northeast. Ideas BTDTs welcome. |
Rob-O |
Sep 18 2023, 08:24 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Not to get you side tracked. But I’ll bet the high beam light is working. What I’ve found is that the blue ‘lens’ that the light shines through ages poorly and doesn’t allow the light through. If you leave the gauge out and check the light that way I’ll bet it illuminates.
And not to send you down another path…you can replace those colored parts. I did the low fuel light years ago and using two or three pieces of plastic that I used from a set of hanging folder plastic tabs. If you ever notice the low fuel red piece on most cars is faded out. I just cut a few small pieces and layered them together and taped them back on the gauge (that is how the factory had it iirc). Two or three layers gave it the correct shade of red when the light was illuminated. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:25 AM |
