Alfa Calipers |
Alfa Calipers |
rgalla9146 |
Sep 20 2023, 09:34 AM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
What Alfa Romeo alloy caliper (from what model car) is suitable to replace 3" front calipers ? AND...is it suitable for use on the rear of a 914 with 911 vented rotors ? provided 911 emergency brakes are adapted. TIA |
technicalninja |
Sep 21 2023, 06:35 AM
Advanced Member Group: Members Posts: 2,200 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Every proportioning valve I've messed with REDUCES pressure and flow to the rear.
The valves do not have the ability to increase pressure or flow to anything. You could put a real proportioning valve in backwards and reduce pressure to the fronts but that sounds like a poor decision IMO. Balancing the caliper piston sizes is the best way to gross balance a system and the 48mm pistons appear to be too large for application on the rear. Found this in the classics forum and it's appropriate for this thread. http://www.914world.com/bbs2/index.php?showtopic=55559 One nice thing regarding the original relief valve is that it doesn't care about balance at all. It just stops all pressures above 525 from reaching the rear calipers. It's adjustable as well. Testing and adjusting it might be sketchy... It's too bad PatMC is right. Looked like a possible candidate for the rears. Still looks like these could be used on the front, however. They would be the same as the BMW calipers, just made out of aluminum. Final thought. The ratio of front to rear that Porsche used is 42/33 4 cylinder and 48/38 on the six cylinders. On a 4 cylinder the size of the rears is 78.5% of the fronts and on the six it's 79.1%. Staying close to this 80% ratio is the way to go in my book. Most cars use a front to back ratio of 75-80% so Porsche was "normal" in how they set up brake bias. Proper fronts for a 914 with 48mm rear pistons would be nearly 60mm on the fronts and you'd need a much larger master. |
mate914 |
Sep 21 2023, 10:26 AM
Matt Group: Members Posts: 802 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Every proportioning valve I've messed with REDUCES pressure and flow to the rear. The valves do not have the ability to increase pressure or flow to anything. You could put a real proportioning valve in backwards and reduce pressure to the fronts but that sounds like a poor decision IMO. Balancing the caliper piston sizes is the best way to gross balance a system and the 48mm pistons appear to be too large for application on the rear. Found this in the classics forum and it's appropriate for this thread. http://www.914world.com/bbs2/index.php?showtopic=55559 One nice thing regarding the original relief valve is that it doesn't care about balance at all. It just stops all pressures above 525 from reaching the rear calipers. It's adjustable as well. Testing and adjusting it might be sketchy... It's too bad PatMC is right. Looked like a possible candidate for the rears. Still looks like these could be used on the front, however. They would be the same as the BMW calipers, just made out of aluminum. Final thought. The ratio of front to rear that Porsche used is 42/33 4 cylinder and 48/38 on the six cylinders. On a 4 cylinder the size of the rears is 78.5% of the fronts and on the six it's 79.1%. Staying close to this 80% ratio is the way to go in my book. Most cars use a front to back ratio of 75-80% so Porsche was "normal" in how they set up brake bias. Proper fronts for a 914 with 48mm rear pistons would be nearly 60mm on the fronts and you'd need a much larger master. Good info. So what should I do? I have Boxster fronts and the Alfa rears? What would be the ideal front and brakes set up for a track/road car? Matt |
Lo-Fi Version | Time is now: 5th January 2025 - 01:46 AM |
