Voltage Regulator, Need help finding right regulator |
ws6 |
Oct 25 2016, 08:49 PM
Newbie Group: Members Posts: 5 Joined: 25-October 16 From: california Member No.: 20,526 Region Association: Central California |
Help. I have gotten three voltage regulators from the normal Porsche Parts suppliers and none fit. The distance from edge of case to the first spade is .25 inches on my original regulator. The catalogs all show same regulator for 911, 914, and 914-6. The ones I have received vary from .4 from the edge to .65 from the edge all with same PN so will not fit in area to plug into. Anyone know the actual part to buy? My original has numbers on it in this order 0 190 601 006 AD 1/14V. The replacements show up as PN 901 603 206 02 Yes I can rewire, or maybe take both apart and move the guts, but trying to keep original and not have a wire harness to convert to get wires to new regulator. Thank you for your help. Tim
Spoke |
Feb 19 2017, 08:25 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I picked up this one locally from Autozone. Works fine.
VaccaRabite |
Jun 14 2022, 12:27 PM
En Garde! Group: Admin Posts: 13,544 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
fixer34 |
Jul 13 2022, 09:26 PM
Senior Member Group: Members Posts: 1,155 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I picked up this one locally from Autozone. Works fine. This is what I am using as well. Zach Interesting; my local Autozone wants $37.99 for it, but says lifetime warranty. Also, one of their pictures shows the connectors in the epoxy bottom, but the others show a 3 wire stub cable with the connector. Wonder if the guy who makes up the pictures has ever seen one. |
bbrock |
Jul 13 2022, 09:40 PM
Interesting; my local Autozone wants $37.99 for it, but says lifetime warranty. Also, one of their pictures shows the connectors in the epoxy bottom, but the others show a 3 wire stub cable with the connector. Wonder if the guy who makes up the pictures has ever seen one. Yeah, those pictures are what threw me. Autozone couldn't get one to me for a week so I bought this one from O'Reilly's which should be here in the morning. |
stoneman30hotmail |
Sep 22 2023, 04:02 PM
Member Group: Members Posts: 80 Joined: 10-September 22 From: Greensboro, NC Member No.: 26,834 Region Association: South East States |
Interesting; my local Autozone wants $37.99 for it, but says lifetime warranty. Also, one of their pictures shows the connectors in the epoxy bottom, but the others show a 3 wire stub cable with the connector. Wonder if the guy who makes up the pictures has ever seen one. Yeah, those pictures are what threw me. Autozone couldn't get one to me for a week so I bought this one from O'Reilly's which should be here in the morning. Re-reviving an old post. I would have liked to know that that part doesn't quite fit. It was nice that O'reilys can get the part within a day for just over 50$. But the tab offset is too short. So, I cut of it off. Now there's 14V at the battery. So maybe that's ok. The generator light is still on though. |
Spoke |
Sep 22 2023, 05:40 PM
Now there's 14V at the battery. So maybe that's ok. The generator light is still on though. @stoneman30hotmail Good that you have 14V at the battery. What is the voltage at D+ to chassis? The voltage across the GEN light is the difference between D+ and battery (through fuse F9). If D+ is also 14V, then with engine off, pop out the guage with GEN light, start the car and measure both sides of the GEN light. They should be the same. |
stoneman30hotmail |
Sep 23 2023, 08:57 AM
Now there's 14V at the battery. So maybe that's ok. The generator light is still on though. @stoneman30hotmail Good that you have 14V at the battery. What is the voltage at D+ to chassis? The voltage across the GEN light is the difference between D+ and battery (through fuse F9). If D+ is also 14V, then with engine off, pop out the guage with GEN light, start the car and measure both sides of the GEN light. They should be the same. 17V at D+! What's that mean? |
Lo-Fi Version | Time is now: 21st September 2024 - 07:12 PM |
