brettrarnold |
New 914 owner in Lakewood CO ![]() ![]() Group: Members Posts: 90 Joined: 11-September 15 From: Lakewood, Colorado Member No.: 19,149 Region Association: Rocky Mountains ![]() |
Background
This car was the first car that Brett drove when he was 13 and was given to us in 2014. It had been sitting idle back in Indiana under a family friend's carport for the past 15 years before Brett went back to Indiana and towed it out to Colorado with his father in July 2014. (IMG:style_emoticons/default/piratenanner.gif) When we got it, we didn't have a garage to work on it and it sat idle being stored outside for another year until we could afford a house with a garage. Colorado is pretty expensive so after we got a house with a garage, we then needed to save up more money to work on it. Also I must mention in my ignorance, there were 3 distinct phases of thinking for getting this car fixed which I now find funny and are listed below Phase 1: I will tow this car out to Colorado and get it the engine running for maybe $2,000 and have a working car. Phase 2: Holy shit after researching this is impossible and will have to pay somebody to fix it for $15-20k. Phase 3: I have enough local support and 914world resources and can fix this myself for around $10-15k. Build-Off Challenge So Amy and I are going to be tackling different aspects of this car so the posts will be coming from both of us. I will handling the rust/engine work and Amy will be on Interior and Exterior. Also she may help with some of the posting so we will start each post with name. Brett Step 1 (Complete) was to remove the engine and assess the frame rust situation. Never having removed an engine from a car, this was an extremely daunting task. The steps listed in Pelican Parts tutorial - 914 Engine Removal Made Easy is by far the most difficult thing I have done to a vehicle thus far. Hell I don't even know the difference between a camshaft and a carburetor much less a CV joint or a clutch cable. But after staring at it for about 2 weeks, I decided to just start unhooking shit and labeling. Made a ton of progress and finally got the engine about 95% unhooked. Had a friend come over to help me out and we actually got it out. WOOHOO!!! Step 2 (Complete) is to strip out all the interior. I ordered chassis braces and other misc items from Tangerine racing and am still in the process of identifying all the rust areas that need repair. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() Attached image(s) ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif)
brettrarnold |
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,811 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? You don’t just tie in. You sit down with the harness and a Subaru wire schematic and 30-50 hours later, you have a harness that will plug into your car. Seriously, if you aren’t good at wire schematics, send it out to a pro. |
brettrarnold |
Unless you plan to AX the stock brakes are fine. I haven't seen Jeffs914's harness' but I can tell you that you can make your own harness (if you have a donor harness from the Subaru donor car) for pennies then tie into the existing 914 harness. (IMG:style_emoticons/default/beerchug.gif) How do i tie into the existing 914 harness? You don’t just tie in. You sit down with the harness and a Subaru wire schematic and 30-50 hours later, you have a harness that will plug into your car. Seriously, if you aren’t good at wire schematics, send it out to a pro. I would be more than happy to send it to a pro... just need to find said pro! |
brettrarnold |
What I find as the easy way to post pictures since I prefer to do from my computer is to do the following. Take picture with your phone. Send to yourself or transfer via cable. Open picture on PC. Use snipping tool that has been part of all windows OS since at least Windows 7. Save Snip and upload. You can edit, crop add text or circle in snipping tool. john I actually got a pretty nice little system with an old camera just sized down basically to thumbnails and then i have an SD card slot that reads the card and then am able to add them to 914 world.... so pretty easy all things considered. |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:55 AM |
