> Fun with Electricity, PO Stuff #5 in the series, or is it #6?
NARP74
post Sep 25 2023, 12:25 PM
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around?
More in this thread to follow. I found lots of crap...
NARP74   Fun with Electricity   Sep 25 2023, 12:25 PM
87m491   They are not in the same location/order as mine, b...   Sep 25 2023, 12:47 PM
NARP74   I guess the bases could be swapped. I'll have...   Sep 25 2023, 12:50 PM
Dave_Darling   The electrons don't care where the relays are....   Sep 26 2023, 01:26 AM
914Sixer   I see lots of NON STOCK wires in the background. ...   Sep 26 2023, 05:36 AM
NARP74   I have not even started looking at the non stock w...   Sep 26 2023, 10:06 AM
NARP74   It gets worse. Why was this cut and bypassed?   Sep 26 2023, 10:08 AM
Spoke   It gets worse. Why was this cut and bypassed? ...   Nov 21 2023, 11:23 AM
NARP74   What is this add on wire for?   Sep 26 2023, 10:08 AM
87m491   That is a jumper wire to make the later 5 pin dire...   Sep 26 2023, 07:59 PM
jim_hoyland   I had a similiar issue and is was: “If the left ...   Sep 26 2023, 10:50 AM
NARP74   Swapped relays with others I had, no change. Foun...   Oct 14 2023, 02:35 PM
NARP74   Been working on this for a while now. I managed t...   Nov 17 2023, 01:03 PM
NARP74   Any ideas here???   Nov 18 2023, 10:28 AM
Ishley   I can’t say definitively… but I had gremlins i...   Nov 18 2023, 07:09 PM
campbellcj   ^^^ I just went thru the same thing - pulled my ha...   Nov 19 2023, 07:32 AM
NARP74   Buying NOS or used old ones on Samba? Any good ne...   Nov 19 2023, 08:59 AM
campbellcj   Buying NOS or used old ones on Samba? Any good n...   Nov 20 2023, 05:24 PM
Tbrown4x4   I have had good luck finding intermittent shorts b...   Nov 19 2023, 09:06 AM
NARP74   I have had good luck finding intermittent shorts ...   Nov 19 2023, 09:23 AM
76-914   After you cleaned and replaced the bulbs you now h...   Nov 19 2023, 09:23 AM
NARP74   After you cleaned and replaced the bulbs you now ...   Nov 19 2023, 09:30 AM
Spoke   I figured out it was the left turn signal. Keep ...   Nov 19 2023, 09:57 AM
Tbrown4x4   I have had good luck finding intermittent shorts...   Nov 19 2023, 06:31 PM
NARP74   So the latest is that the fuse has stopped blowing...   Nov 20 2023, 09:27 AM
Spoke   And for the dial gauge indicators, are the arrows...   Nov 20 2023, 09:57 PM
87m491   I can't be the only one trying to use LED bu...   Nov 22 2023, 03:08 PM
NARP74   I can't be the only one trying to use LED b...   Nov 22 2023, 03:40 PM
VaccaRabite   Its the switch. You need a switch that is designe...   Nov 20 2023, 10:57 AM
NARP74   I have talked to a few people and verified on anot...   Nov 20 2023, 01:58 PM
NARP74   Car is a 74, but... it has a Gates dash conversion...   Nov 21 2023, 09:16 AM
Spoke   Car is a 74, but... it has a Gates dash conversio...   Nov 21 2023, 11:07 AM
majkos1   Don't you have Five gauges ? That's a Gett...   Nov 21 2023, 04:46 PM
NARP74   Don't you have Five gauges ? That's a Get...   Nov 22 2023, 09:14 AM
- Lo-Fi Version Time is now: 15th January 2025 - 05:35 AM
