Fun with Electricity, PO Stuff #5 in the series, or is it #6? |
NARP74 |
Sep 25 2023, 12:25 PM
Senior Member Group: Members Posts: 1,308 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around?
More in this thread to follow. I found lots of crap... |
87m491 |
Sep 25 2023, 12:47 PM
Member Group: Members Posts: 327 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
They are not in the same location/order as mine, but I don't believe you can swap relays into the wrong receptacles/slots as the pin configurations are different for the Wehrle and the square units..
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around? More in this thread to follow. I found lots of crap... |
Lo-Fi Version | Time is now: 15th January 2025 - 05:40 AM |
