> Alfa Calipers
rgalla9146
post Sep 20 2023, 09:34 AM
What Alfa Romeo alloy caliper (from what model car) is suitable to replace 3"
front calipers ?
AND...is it suitable for use on the rear of a 914 with 911 vented rotors ? provided
911 emergency brakes are adapted.
TIA
rgalla9146
post Sep 28 2023, 01:01 PM
Hey Luke
I have S alloy calipers on the front and 914 6 rear calipers (widened 10mm for
vented 911 rotors) on the rear.
With the 6 rear calipers the ebrake cables rub against the exhaust.
This is especially true with headers.
To remedy this I'm going to install 911 ebrakes... I need to find suitable rear calipers.
I do have a full set of 944 turbo calipers and a 23mm MB master.
How did the 944 Turbo calipers mount to the 3 1/2" struts ... and can they mount to the 914 trailing arms ?
As you probably know I'm running 16" Fuchs so no clearance issues.
porschetub
post Sep 29 2023, 12:38 PM
QUOTE(rgalla9146 @ Sep 29 2023, 07:01 AM) *
Hey Luke
i have 944T brembo's front and rear which were fitted by PO, I believe the rears are mounted by welding up the old threaded holes and repositioning them,the struts have machined offset inserts threaded into them which as an engineer I think is a clever solution.
All calipers have special 1mm spacer washers that fit between mounting ears I presume these are to centre the calipers to disks , running ER 5mm "shim'' spacers @ the front with 7x16 Fuchs .
PO added new 19mm master cylinder and the whole lot works very well together ,only solution in our country as adaptors are illegal. .
rgalla9146   Alfa Calipers   Sep 20 2023, 09:34 AM
mepstein   GTV6 I believe. You can usually find them on eBay....   Sep 20 2023, 09:50 AM
mate914   What Alfa Romeo alloy caliper (from what model ca...   Sep 20 2023, 10:30 AM
rgalla9146   What Alfa Romeo alloy caliper (from what model c...   Sep 20 2023, 10:53 AM
mate914   [quote name='mate914' post='3102960' date='Sep 20...   Sep 20 2023, 01:30 PM
mepstein   The Suby conversion car I just sold had a pair of ...   Sep 20 2023, 12:00 PM
PatMc   A 48mm piston is way too much for the rear of a 91...   Sep 20 2023, 05:48 PM
rgalla9146   A 48mm piston is way too much for the rear of a 9...   Sep 20 2023, 08:43 PM
mepstein   A 48mm piston is way too much for the rear of a ...   Sep 20 2023, 09:12 PM
mate914   A 48mm piston is way too much for the rear of a 9...   Sep 21 2023, 04:41 AM
mepstein   A 48mm piston is way too much for the rear of a ...   Sep 21 2023, 05:29 AM
technicalninja   Every proportioning valve I've messed with RED...   Sep 21 2023, 06:35 AM
mate914   Every proportioning valve I've messed with RE...   Sep 21 2023, 10:26 AM
mepstein   [quote name='technicalninja' post='3103106' date=...   Sep 21 2023, 10:35 AM
mate914   [quote name='technicalninja' post='3103106' date...   Sep 21 2023, 01:26 PM
mepstein   [quote name='mepstein' post='3103145' date='Sep 2...   Sep 21 2023, 02:13 PM
PatMc   It's too bad PatMC is right. Looked like a p...   Sep 22 2023, 09:40 PM
bdstone914   What Alfa Romeo alloy caliper (from what model ca...   Sep 21 2023, 09:35 PM
mlindner   I installed SC's on the front with 48mm piston...   Sep 22 2023, 01:05 PM
mepstein   The Alfa calipers on the front are a neat replacem...   Sep 23 2023, 05:02 AM
ConeDodger   Alfa like this? I was an early adopter. Eric She...   Sep 23 2023, 05:24 AM
mepstein   Alfa like this? I was an early adopter. Eric Sh...   Sep 23 2023, 07:24 AM
rgalla9146   Alfa like this? I was an early adopter. Eric Sh...   Sep 25 2023, 08:00 AM
ConeDodger   Alfa like this? I was an early adopter. Eric S...   Sep 29 2023, 09:19 PM
Luke M   Hi Rory, Is this setup for the white GT ? On my ...   Sep 25 2023, 02:47 PM
rgalla9146   Hey Luke I have S alloy calipers on the fron...   Sep 28 2023, 01:01 PM
burton73   Hey Luke I have S alloy calipers on the fro...   Sep 28 2023, 02:24 PM
rgalla9146   [quote name='rgalla9146' post='3104562' date='Sep...   Sep 28 2023, 07:20 PM
burton73   Hey Bob Tell me about the Boxter rears and t...   Sep 28 2023, 09:21 PM
Luke M   Hey Luke I have S alloy calipers on the fro...   Sep 29 2023, 07:30 AM
porschetub   Hey Luke I have S alloy calipers on the fro...   Sep 29 2023, 12:38 PM
brant   Took my vented rears off the race car 20 years bac...   Sep 28 2023, 05:51 PM
mate914   Took my vented rears off the race car 20 years ba...   Sep 28 2023, 07:11 PM
burton73   Hi Rory This is what I think are the fronts with ...   Sep 29 2023, 08:02 AM
rgalla9146   Good update on rear calipers. I found these am...   Sep 30 2023, 06:19 PM
mate914   Good update on rear calipers. I found these a...   Sep 30 2023, 06:37 PM
PatMc   Good update on rear calipers. I found these ...   Sep 30 2023, 07:43 PM
rgalla9146   Next mystery. I've had these 911(what year...   Sep 30 2023, 06:59 PM
mate914   Next mystery. I've had these 911(what yea...   Sep 30 2023, 07:14 PM
mb911   Next mystery. I've had these 911(what yea...   Oct 1 2023, 06:20 AM
mepstein   Next mystery. I've had these 911(what ye...   Oct 1 2023, 07:00 AM
mb911   [quote name='mb911' post='3105249' date='Oct 1 20...   Oct 1 2023, 06:07 PM
rgalla9146   Next mystery. I've had these 911(what ye...   Oct 1 2023, 09:38 AM
Luke M   [quote name='mb911' post='3105249' date='Oct 1 20...   Oct 2 2023, 07:54 AM
mepstein   @MB911 Ben did the conversion recently and needed...   Sep 30 2023, 07:02 PM
mate914   Those brake shoes look like the right parts. The c...   Sep 30 2023, 07:17 PM
mate914   Am I going to have to take my brakes apart and tak...   Oct 1 2023, 12:00 PM
rgalla9146   Am I going to have to take my brakes apart and ta...   Oct 1 2023, 12:21 PM
mb911   Here is my set up done.   Oct 1 2023, 06:13 PM
Luke M   Here's the e-brake pad and hardware info. The ...   Oct 2 2023, 09:46 AM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th January 2025 - 01:29 AM
