> chassis number decoder, is this right?
914 RZ-1
post Feb 21 2016, 05:09 PM
Porsche Padawan
So I'm looking for something that will tell me what the numbers mean on the chassis number. I find the "chassis number decoder" info shown. However, it doesn't seem to work. Am I missing something? My chassis number-found on the inside front fender on a plate (is this supposed to be the same as the VIN number?)-is 472 2910951, door sticker says car was built in Feb '72.
So using the decoder it seems my car was built in the 29th week of the year (29) on Monday (1) at the Karmann factory (9) and it was the 51st car built that day.
By the way, the chassis plate states the car was "Made in Germany", but there was a West and East Germany back then, so what gives?
mgarrison
post Oct 4 2023, 11:28 AM
So, my chassis # = 4649581 and my VIN = 4742908715 with an 11/73 build date.
Then:
46 = 46th week of 1973
4 = Thursday
9 = Karmann Factory
581 = 81st build of the day (nobody knows what that pesky "5" is...???)
So...November 15, 1973
Did I work that out correctly (IMG:style_emoticons/default/confused24.gif)
If so, that's pretty COOL because our daughter's birthday is November 15th! (IMG:style_emoticons/default/cheer.gif)
wonkipop
post Oct 7 2023, 05:47 PM
QUOTE(mgarrison @ Oct 4 2023, 11:28 AM) *
Then:
4 = Thursday
9 = Karmann Factory
the pesky 5 is the number assigned to 914s on the karmann assembly line up to the first 100. then it flipped to a 6 if they went over 100 for the day (which they rarely did).
other cars on the k production line got a different number at that location.
something like 1 and 2 for the beetle cabs and 3 and 4 for ghias. not sure i have the actual number assigned correct but they got different numbers.
later when they shut down the ghia line and moved the 914s across to the cab line with the beetles the 914s got a different number instead of 5 and 6. if i recall when i looked into this they might have got the ghias old numbers. but there was also a week where they got scrambled. dave p knows all about it. i think the scirrocos ended up with the numbers that the 914 had from 70 to 74.
the number on the karmann plate is a VW production number. all VWs of that era have it. depending on the factory or the model where the VW was made the factory number is different. ie its not a 9 if its not the karmann plant. and the next number after that is different depending on the model being made at the factory. some models got more than two numbers allocated for the sequencing of cars for the day. they were making a lot more than 100 beetles for instance at wolfsburg than 100 per day. (IMG:style_emoticons/default/biggrin.gif)
914 RZ-1   chassis number decoder   Feb 21 2016, 05:09 PM
Coondog   Your correct with the chassis number date that you...   Feb 21 2016, 05:20 PM
Larmo63   The VIN and the chassis numbers are different. The...   Feb 21 2016, 06:17 PM
dlkawashima   RE: chassis number decoder   Feb 21 2016, 09:57 PM
SirAndy   Am I missing something? My chassis number-found on...   Feb 22 2016, 12:12 PM
914 RZ-1   According to the Haynes manual the chassis number ...   Feb 25 2016, 06:28 PM
boxsterfan   According to the Haynes manual the chassis number...   Feb 25 2016, 09:24 PM
SirAndy   According to the Haynes manual the chassis number ...   Feb 25 2016, 09:33 PM
Jeff Bowlsby   Haynes is a British publication. To them, they ma...   Feb 25 2016, 09:46 PM
914 RZ-1   I finally got around to taking all the paint off a...   Mar 29 2016, 05:54 PM
stevend914   Question on counting the weeks: In my case the fi...   Dec 11 2018, 03:08 PM
jagalyn   Question on counting the weeks: In my case the f...   Nov 8 2021, 05:32 AM
jagalyn   My car was the 110th car built on Monday, April 9...   Dec 12 2018, 08:18 PM
aharder   Mine was the 6th one on Monday October 1974 :D   Dec 12 2018, 09:04 PM
Larmo63   How many 914s did the Karmann factory pump out per...   Jul 7 2019, 10:37 PM
Craigers17   Looks like the made 21,580 914's in 1972, not ...   Jul 8 2019, 04:03 AM
Front yard mechanic   :stooges: Edit   Oct 4 2023, 04:31 PM
jagalyn   So, what does the ‘5’ stand for?   Jul 8 2019, 05:46 AM
Larmo63   If the "5" isn't included in the car...   Jul 8 2019, 09:14 AM
914 RZ-1   I was looking at this post again. Thought I'd ...   Jul 13 2019, 06:06 PM
SirAndy   Not sure why it starts with a 5 in that column but...   Jul 13 2019, 08:54 PM
EdwardBlume   Found this tag on the ABM Chassis born on July 4t...   Nov 22 2020, 12:39 AM
emerygt350   So mine says 9/72 but I can't figure that out ...   Sep 27 2023, 04:28 PM
SirAndy   So mine says 9/72 but I can't figure that out...   Sep 27 2023, 05:15 PM
emerygt350   So mine says 9/72 but I can't figure that ou...   Sep 28 2023, 10:41 AM
Olympic 914   So mine says 9/72 but I can't figure that ou...   Oct 5 2023, 02:31 PM
76-914   Re: My 1976 914; Would I still use calendar year ...   Oct 2 2023, 02:23 PM
davep   NO! 4762901295 would be 10/75   Oct 2 2023, 02:27 PM
76-914   Let me see if I have this correct. If my chassis #...   Oct 3 2023, 10:13 AM
dax1969   Interesting... 3419547 week 34 1974 - august 1 =...   Oct 4 2023, 04:14 AM
mgarrison   So, my chassis # = 4649581 and my VIN = 4742908715...   Oct 4 2023, 11:28 AM
sixaddict   So does this same formula work for 914-6 ( specifi...   Oct 6 2023, 05:58 AM
wonkipop   So, my chassis # = 4649581 and my VIN = 474290871...   Oct 7 2023, 05:47 PM
76-914   The quotation in the 1st post says that only 70-74...   Oct 4 2023, 02:52 PM
fixer34   Does any of this apply to the -6 models? My Karma...   Oct 5 2023, 02:46 PM
wonkipop   Does any of this apply to the -6 models? My Karm...   Oct 7 2023, 05:57 PM
davep   the karmann plate would be stamped with the porsc...   Oct 7 2023, 08:26 PM
Dave_Darling   I think the -6 chassis did not use this numbering ...   Oct 5 2023, 02:53 PM
davep   email me for more info: Kardex@bell.net Dave P   Oct 5 2023, 07:14 PM
ClayPerrine   Just a related side note... I took a picture of t...   Oct 7 2023, 08:11 AM
SirAndy   Just a related side note... I took a picture of t...   Oct 7 2023, 05:25 PM
ClayPerrine   [quote name='ClayPerrine' post='3106431' date='Oc...   Oct 7 2023, 07:29 PM
wonkipop   [quote name='ClayPerrine' post='3106431' date='O...   Oct 7 2023, 08:13 PM
JeffBowlsby   DP   Oct 7 2023, 09:50 PM
JeffBowlsby   Just a related side note... I took a picture of ...   Oct 7 2023, 09:50 PM
Gint   [b]@[url=http://www.914world.com/bbs2/index.php?...   Oct 8 2023, 09:27 AM
Maltese Falcon   [quote name='ClayPerrine' post='3106431' date='Oc...   Oct 8 2023, 06:43 PM
mate914   My paint code tag says 849548 8th week 4th day ...   Oct 8 2023, 08:42 AM
76-914   My paint code tag says 849548 8th week 4th day ...   Oct 8 2023, 10:01 AM
mate914   My paint code tag says 849548 8th week 4th day...   Oct 8 2023, 11:50 AM
flat4guy   not sure why mine is a low number but chassis 0719...   Oct 10 2023, 09:25 PM
wonkipop   not sure why mine is a low number but chassis 071...   Oct 11 2023, 02:59 AM
76-914   RE: chassis number decoder   Oct 11 2023, 08:56 AM
chmillman   Just checking in here, have now acquired a 914/4 i...   Jul 26 2024, 04:33 AM
mate914   Ok, I got the right number now. 1970 914-6 1306...   Jul 26 2024, 05:01 AM
gms   Ok, I got the right number now. 1970 914-6 130...   Jul 30 2024, 10:14 AM
SirAndy   @chmillman Production for a specific model year a...   Jul 26 2024, 09:00 AM
- Lo-Fi Version Time is now: 15th January 2025 - 07:31 AM
