Well, I did a thing, It was a thing I knew better then to do, too. (Thermocouple connecting) |
VaccaRabite |
Oct 11 2023, 06:22 AM
En Garde! Group: Admin Posts: 13,584 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Continuing to live my life as an object lesson for others...
I recently had to pull my engine for some repairs. For me, part of pulling the engine includes removing the thermocouple from under the #3 spark plug and fishing it out of the engine tins. This runs to the CHT gauge in the cabin of the car. And we all know you are not supposed to cut the wire. Everybody knows that. So I figured I'd cut the wire, add a nice weatherproof automotive plug, and see what happens. All in the name of convenience and curiosity. I drove 300 miles last weekend. Including going fast up a really long couple of hills (like miles long hills) in 5th gear. So the results.... At cold start, the gauge reads the same as ambient temps. Under normal driving, the CHT gauge read slightly cooler then before I added the plug, but within 10 degrees of what I expected. However, when pushing the car, the error rate grew exponentially. Where I would expect the car to be running 340-350 head temps, the gage only showed about 300. And pushing 90 up hill in 5th for over a mile I would expect the gage to read 360+ the gage only ever got to 325. I did not push past what I know this engine required to get to 375 (which is my back off point). The result of this experiment is that if I did not know and expect bogus returns on the gage, I could easily roast an engine and start dropping valve seats, while a quality CHT gage was reporting I was WELL under the 400 degree danger zone. I have another cable I can swap in. Kind of a pain, but not a huge deal. I'll add it o the maintenance schedule. But, yeah. In this case the group think is accurate. The very slight resistance that the plug will add to the cable will be enough to throw off your CHT monitor. Do not cut the line between the thermocouple and your CHT gage. Zach |
barefoot |
Oct 12 2023, 10:08 AM
Senior Member Group: Members Posts: 1,326 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Here's what I used, extension is long enough to route thru center tunnel up to under dash gauge. A very cheap solution.
https://www.ebay.com/itm/203517821362 |
Geezer914 |
Oct 12 2023, 03:52 PM
Geezer914 Group: Members Posts: 1,749 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Here's what I used, extension is long enough to route thru center tunnel up to under dash gauge. A very cheap solution. https://www.ebay.com/itm/203517821362 Did this work with a Dakota Digital gauge? |
stownsen914 |
Oct 12 2023, 10:28 PM
Senior Member Group: Members Posts: 928 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
stownsen914 |
Oct 12 2023, 10:43 PM
Well I asked the vendor and got this response:
Yes, the VDO CHT gauge normally use K type thermocouple as input and it is fully compatible with our sender. Please make sure that the yellow wire is connected to the positive and the red wire is connected to the negative. It should work. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:24 PM |
